Remote Start for 2009 F150 - Ford Truck Enthusiasts Forums
Old 05-30-2010, 05:48 PM
george6488 george6488 is offline
george6488 is starting off with a positive reputation.
Searched the threads but did not find any details. Has anyone added remote start by themselves? What is the part numbers? Costs? Does the dealer have to get involved for any programming?
Old 05-31-2010, 04:50 PM
xciton xciton is offline
xciton is starting off with a positive reputation.
I too am interested in this. I have an on-order F150, and I would like to have the factory remote start + alarm system installed (the gold version).
I've read the install manual from Ford. Doesn't seem too difficult, but there are half dozen splices that need to be done do existing wiring (why doesn't Ford make this a 100% plugin?). Look's like a full day's job to do everything properly (soldered joints, properly routed wires).
One potential issue is that the manual states you should have the vehicle wiring diagram for reference. I don't have access to this.
It would save about 400 $CDN.
There is no dealer re-programming required, other than configuring the remote start + alarm system with the keyfob/horn.
Old 05-31-2010, 09:26 PM
We will probably get more responses after the holiday
Old 06-01-2010, 09:55 AM
SteveVFX4 SteveVFX4 is offline
SteveVFX4 is starting off with a positive reputation.
I have done about 3 myself in the past on older trucks, but I did not do my 09 F150. It would take me all day. Luckily I found a local installer who came to my house and he installed my 6-button Ford rmst with alarm system in only an hour for just $80 cash install fee.
Here are the 3 different Ford systems offered with the part numbers and a picture of the remote fob that comes with it (NOTE: These are 2009 part numbers only, the part numbers changed for the 2010 systems because of the new My-Key feature).
Remote Start only (basic system) Part Number: 7W3Z-19G364-AA
Remote Start only, Bi-Directional (2-way) Part Number: 9C3Z-19G364-A
Remote Start, With Keyless Entry & Alarm Part Number (gold system): 7L3Z-19G364-AA
For the first two remote start systems, you would have to carry your factory keyless entry fob with you too. I think the first one is the one you get as the factory invoiced accessory remote start system if you order your truck with it. The second one is actually a 2-way type system, the button flashes green and the keyfob beeps to confirm that the truck started. The third system includes the alarm, and it replaces your factory keyless fob since the new fob does control keyless entry and remote start all in one fob. The extra 1 and 2 buttons on the fob are pretty much useless for our trucks. You could turn the alarm feature off if you want (if you don't like alarms), but at least then you would still have everything all in one key fob rather than having to carry 2 fobs around.
The 3 systems cost between $200 and $230 plus shipping through an online discount Ford parts dealer. Sometimes you can find them slightly cheaper on Ebay. I lucked out and I think I bought my 6-button system for around $150 or so on Ebay.
For either system, you also need the Ford PATS Interface/bypass kit, the part number is 8L3Z-19G365-BA. It costs around $25 plus shipping. You just need your 2 master keys to program this kit. You don't have to take your truck to the dealer to program the PATS kit or the remote start/alarm system.
The first two remote start only systems above actually install pretty easy now, they come with a plug-in harness that plugs directly into our trucks. Then there’s only about 6 wires or so left that you have to splice-in yourself. The 6-button remote start with alarm system does not come with any type of plug-in harness, so you have to tap/splice all of the necessary wires (about 16 or so total). Most of the wires you tap into are along the steering column and driver's side kick panel/door sill, but there's also 1 or 2 wires that you tap into at the passenger side kick panel at the smart junction box (SJB).
You can find some of the Ford technical install manuals here:
Technical Specifications
Just select “installation instructions” and then “electronics” and within there are the remote start and alarm files.
I also have a DEI/Viper wiring diagram too for the 09 F150 that describes the wire locations a little better, if you email me through my profile, I can email it to you. Or if anyone wants to reply here with their email address, I'll send it to you.
Old 06-01-2010, 09:38 PM
WOW..............thanks
I contacted PartGuyEd and he quoted $204.00 for the standard remote start kit and $36.00 for the PATS interface
Old 06-02-2010, 11:35 AM
SliderF150's Avatar
SliderF150 SliderF150 is offline
SliderF150 is starting off with a positive reputation.
I have the 3rd one posted above and was about $550 CDN installed by the dealer when I bought the truck....
Old 06-13-2010, 07:21 PM
Smile
I ordered the parts for the "basic" from Parts Guy Ed. Kits due in late this week.....maybe get installed on Father's day.
I went with the basic for the plug-in harness and minimal splices.
Will update in about a week.
Old 07-05-2010, 10:15 PM
UPDATE.....I ordered the basic kit from PartsGuyEd along with the PATS adapter that is required. SteveVFX4 offered great information and made the whole process un-complicated.
The shipment from PartsGuyEd took about 1 week and now the install task was at hand. I looked at the kit and I saw about 9 wires to splice plus several plug-in harnesses. The PATS adapter and antenna looked like the big challenge and the small area under the dash to work. The heat in South Texas is over 95 most days....so I called a smaller Ford dealer for assistance. They said they don't do the work but have an electronics person that comes around and does the install for $120.00.
I made the appointment and the install went perfect. I can't imagine how I got by without this added convenience for so long.
I highly recommend remote start kit from Ford.
Old 07-07-2010, 09:05 AM
sounds good man. yeah most dealers don't have a clue about these systems and they do have a someone that comes in to install them.
Remote start Jay 2007 - 2014 Expedition & Navigator 5 03-12-2014 12:06 AM
Remote Start with Snow Covered Windshield SurryGent 6.7L Power Stroke Diesel 12 01-06-2013 10:40 AM
Factory Remote Start Issues FX4_FAN 1997 - 2003 F150 0 11-29-2012 08:52 PM
Remote Start jez 6.0L Power Stroke Diesel 10 11-18-2012 09:47 PM
Remote Start abah 2004 - 2008 F150 4 10-13-2007 09:41 PM
Tags
2009, alarm, directions, ebay, expedition, f150, ford, gold, harness, pats, plug, programing, remote, start, startalarm, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
