Left keys in truck can I get into rear window - Ford Truck Enthusiasts Forums
Old 05-30-2010, 05:14 PM
eastonfmly eastonfmly is offline
eastonfmly is starting off with a positive reputation.
I am not sure if this is appropriate but I left my only set of keys in the truck. We jsut realized it last week and I was going down to the dealer on Tuesday to get another one.
Before I go through the hassle of getting lockout service in, I was wondering if anyone has a simple way of getting in through the back sliding window without breaking it. I used to do it before I got smarter but just cant figure it out now.
Thanks
Jim
Old 05-30-2010, 07:22 PM
cv18sro cv18sro is offline
cv18sro is starting off with a positive reputation.
I cannot get into the rear window of my 01. I have found slim jiming the door works best. I can get in about 2 to 5 minutes. There is plate over the locking mechanism but when you find the right angle and push down the door unlocks. I tried coat hangers before and they work ok but the window seal is pretty tight and tough to get much leverage on the wire.
Old 05-30-2010, 07:24 PM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
Unless the rules have changed your local Ford dealer should be able to cut you a non-pats key (good for getting the door open) as long as your VIN shows up in the key code section of fmcdealer.com.
You will need to bring proof of ownership, preferably the title that shows the VIN and your name as well as a photo ID, think drivers license.
The non-pats key should cost very little and might come in handy should this happen again.
Call your local Ford parts department and verify that they can or can't help.
Don't know about the rear window .....
Or as mentioned you might get a coat hanger, and try to push the unlock button
Old 05-30-2010, 09:53 PM
Tex1986's Avatar
Tex1986 Tex1986 is offline
Tex1986 is starting off with a positive reputation.
If it's a sliding rear window... just get a flat tip screwdriver and pry the lever away. It works GREAT on my 98. Yes, the same one that leaked from the factory.
Old 05-31-2010, 12:40 PM
djfordman81005's Avatar
djfordman81005 djfordman81005 is offline
djfordman81005 is starting off with a positive reputation.
I can break into my back window with one of the following:
Flat head screwdriver
Coat hanger
FM radio antenna
Anything along those lines should work. Shimmying on through there once its open can be the next challenge
Old 05-31-2010, 02:43 PM
My truck must have after market back window. The locking mechanism is simular to the side windows on my ext cab rear doors. You have to squeeze the tabs and pull. There is no way to open it from the outside.
Not for this truck but a few years ago a friend tried to get a replacement key for his 95 Ford and the dealer told him anything older than 5 years Ford will no longer make keys from the VIN. Not sure if this was laziness or true.
I made a sheetmetal slim jim I hide in the front bumper and it works.
Old 05-31-2010, 09:42 PM
Got in using screw driver just took longer than usual..thanks...my son did the shimmying in
Jim
1999 Expedition no power to window motor Orple 1997-2006 Expedition & Navigator 12 09-10-2016 03:43 PM
Haunted Windows? Pit Crew 1999 to 2016 Super Duty 3 04-06-2015 11:03 PM
Bad GEM Module? schwefel 1999 to 2016 Super Duty 8 11-10-2012 08:34 PM
How can I get rid of my VSM/GEM? NS F250 1999 to 2016 Super Duty 0 06-11-2012 03:44 PM
Strange window behavior Swagtastic Excursion - King of SUVs 0 06-11-2012 11:32 AM
Tags
1998, 1999, 99, back, break, breaking, door, f150, ford, key, rear, sliding, truck, trucks, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
