Lets talk lift kits! 4 inch, 6 inch, what's needed... - Ford Truck Enthusiasts Forums
Old 05-30-2010, 10:06 AM
1BADRIDE 1BADRIDE is offline
1BADRIDE is starting off with a positive reputation.
Ok, looking to freshen up the excursions suspension soon and have been looking at lift kits. I really like the skyjacker kits because they give you an add a leaf in the rear instead of blocks. I don't want a bunch of axle wrap. My question is, how big do I need to go for 35's and what else would I need to do besides what comes in the kit? I noticed a note on one of the kits talking about driveshaft mods and I don't want to do anything like that. What have you guys installed and found is needed or any issues you have run into?
Old 05-30-2010, 10:22 AM
X-Hibition's Avatar
X-Hibition X-Hibition is offline
X-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to allX-Hibition is a name known to all
I can only offer my experience, all positive, with my kit, which is not one of your choices. I used the Icon 5" all spring kit because I wanted to avoid axle wrap. I also wanted 35" tires.
Since the install I have not had a problem with vibration and performed no driveshaft modifications. I did go with every option I could, dual front shocks, dual front stabilizers, adjustable pan rod bar, and since I lifted it and added taller tires I had the X re-geared, added LSD, cryo rotors, new pads, and RAS. But other than that, nothing extra.
Good luck with just lifting it. You ain't seen nuthin' yet...
Old 05-30-2010, 10:28 AM
RMBC Freeride's Avatar
RMBC Freeride RMBC Freeride is offline
RMBC Freeride has a good reputation on FTE.RMBC Freeride has a good reputation on FTE.
I did a DIY 4" lift using used ford springs and a leveling kit... gave me over 4" and clears 35.5" tires. Here is my post: http://www.ford-trucks.com/forums/92...-4-5-lift.html
Old 05-30-2010, 11:34 AM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
4 inches is the minimum to clear 35s...6 inches is overkill.
I'd also suggest an all spring kit as blocks don't seem to cut the mustard. PROcomp, Donahoe Racing, and a few others make an awesome all spring kit. Mine is a PROcomp kit and I'm very satisfied with it...
Just an FYI, myself and Quietman have been running 35s on the factory mags for years without any issues, just in case the addtional expense of new rims wasn't too appealing.
Old 05-30-2010, 01:34 PM
hwybee22's Avatar
hwybee22 hwybee22 is offline
hwybee22 has a great reputation on FTE.hwybee22 has a great reputation on FTE.hwybee22 has a great reputation on FTE.hwybee22 has a great reputation on FTE.
Good point Toreador. Shouldn't rim size be a consideration when deciding on the size of lift?
Old 05-30-2010, 08:12 PM
Slug-O Slug-O is offline
Slug-O is starting off with a positive reputation.
I did a Pro Comp. 4" lift in 315s and could not be happier!!!
Old 05-30-2010, 08:54 PM
Exactly what I needed to hear! Thanks guys! Yeah, i'm sure the lift is just the beginning...lol. I'm already looking at the Edge CTS in the future, exhaust, CAI, and tires. I'm sticking with the factory wheels for now. I just got done installing the Pioneer X710BT nav in it and got the rear dvd to power up, but even if I crank the volume to the max, you can barely hear the rear dvd over the speakers. I used the correct wires I believe, but just not much volume from it. Guess i'll look into converting the audio to wireless or something. I'll have to check out that icon 4" also.
Old 05-30-2010, 09:07 PM
X-Hibition's Avatar
Icon 5" is what I used, not 4".
Old 05-30-2010, 09:25 PM
Quote:
Sorry about that, 5". I'll check it out. Did it come with shocks?
Old 05-30-2010, 10:35 PM
playboy4aday's Avatar
playboy4aday playboy4aday is offline
playboy4aday is starting off with a positive reputation.
I did the 5 inch Rough Country and havent noticed any axle wrap issues. But with that said it comes with antiwrap blocks and shocks as well.
Ford Suspension Lift Kit
Old 05-30-2010, 11:29 PM
I forgot to mention this, but something you may want to consider is having to regear. There will be a noticable drop in fuel economy and power as soon as you slap those 35s on. I know firsthand...
With 35s, you want to regear to 4.10 to make it easier to get and keep your truck moving; I.e. You'll recover your fuel economy and power. You'll also want to look into a 6.0 transcooler and a shiftkit be it TransGo or sonnax.
Old 05-31-2010, 12:08 AM
X-Hibition's Avatar
Yes, I ordered my kit with shocks. Six for the suspension and two for the stabilizer.
And since I already mentioned re-gearing I trust Toreador was agreeing with me. Yes, you will re-gear, or no, you won't like your 35s.
Old 05-31-2010, 09:00 AM
I forgot to say I'm running stock rims and love the look..
Old 05-31-2010, 01:05 PM
Skip the Transgo they suck. I have had them in my cars before and its better to get a aftermarket valve body that actually increaces fluid flow instead of just fooling the trans and just uping line preasure. Check with Factory tech and see if he has something for the X. I put 37x13.50 R20s on mine and it makes a huge dent in you power and fuel economy. All be it still driveable but you will not be passing anyone unless you have a run at them.
Old 05-31-2010, 09:32 PM
ccbrett's Avatar
ccbrett ccbrett is offline
ccbrett is starting off with a positive reputation.
Where did u get the roof rack
lift kits for an 04 4x4 ryan044x4 1999 to 2016 Super Duty 1 11-02-2014 02:02 AM
6 or 4 inch lift with 33s 86fsbronco 1978 - 1996 Big Bronco 20 04-02-2014 02:12 PM
Your thoughts on this SST Fixed Lift Kit tdogmason 1999 to 2016 Super Duty 4 12-01-2011 08:26 PM
Procomp rear leaf springs rockcrawler_101 1999 to 2016 Super Duty 2 11-10-2011 08:31 PM
Lift vs Leveling Kit....a bit confused Sleepsafe 1999 to 2016 Super Duty 14 09-08-2009 11:55 PM
Tags
2001, 6in, body, duty, excursion, ford, icon, inch, issues, kits, lift, rims, stock, super, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
