2004 Ranger, cold hard start
Old 05-30-2010, 12:22 AM
ryan13's Avatar
ryan13
ryan13 is offline
Hi,
I have a 2004 w/ 3.0L flex, 5 spd that suddenly became hard to start cold. Cranks for 20 sec or so then starts, starts better on 2nd crank. Starts right up if hot. Let it set for a bit and it's back to hard start. We've done a fuel pressure test and replaced crank position sensor. Soooooo IAC? MAF? CIA? FBI?
Thanks for any help,
Ryan
Old 05-30-2010, 03:10 AM
g_k50's Avatar
g_k50
g_k50 is offline
Check the TLA
(Three Letter Acronym)
Old 05-30-2010, 06:35 AM
03 Maz B23's Avatar
03 Maz B23
03 Maz B23 is offline
How old are spark plugs and wires? Also I would clean MAF sensor ( on air intake hose near air filter box). Mine has elements on both sides so be sure to clean both with a shot of electrical contact cleaner.
Old 05-30-2010, 08:36 AM
powersmoked's Avatar
powersmoked
powersmoked is offline
Originally Posted by ryan13
Hi,
Ryan
Do i need to be in the CIA or the FBI to find out the results of the fuel pressure test.........and I am sure you did the test when it was running good and running bad.....and I am sure you did a koeo, a koer and you tested to see how far the psi dropped in 5 minutes after the truck was shut off?
TheTinian
08-07-2014 06:33 PM
bpete
04-02-2014 03:24 PM
Polkster
03-01-2014 02:26 PM
armysoopertrooper
11-12-2013 03:04 PM
ryan2258
12-31-2008 05:58 PM
Quick Reply: 2004 Ranger, cold hard start
