Spade connecter at starter is brittle
Old 05-29-2010, 10:18 AM
bang4dabuck's Avatar
bang4dabuck
bang4dabuck is offline
I need to change out my starter and this connection is crumbling in my hand. What do I do when I put my new starter in? Any ideas ?
Also my truck won't start so I'm stuck working in my townhouse development side street (much to my neighbors chagrin I'm sure). Is there a trick to getting easier acces. I was thinking to jacker up and also remove right wheel. Is that it or it is what it is ?
Old 05-29-2010, 02:07 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
Often the bad spade connection IS the starter problem.
Change it first and see if you can save the trouble & $$$
Old 05-29-2010, 02:23 PM
danr1's Avatar
danr1
danr1 is offline
They make a replacement pig tail for that spade connector.
You'd cut it off, solder the replacement connector on and seal splice with heat shrink tubing.
If the auto parts isn't open or doesn't have it in stock, you can make up the same thing at any hardware store.
Old 05-29-2010, 03:46 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
if yours is brittle, it may be too late to repair.
a new starter is a good investment.
Old 05-29-2010, 03:57 PM
bang4dabuck
Cut off, splice, solder ???
I need much better access. Love for it to start so i could move it to a more amicable location. It's pointing down hill right against the curb.I haven't got that connector off yet but maybe by jiggling it, it might start so I can get it moved.
Old 05-29-2010, 04:05 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
If it's standard and pointing downhill just bump start it in 2nd....
rb8484
1999 to 2016 Super Duty
11-24-2013 02:48 PM
Automator
17
08-15-2013 02:42 PM
sarnott140
01-12-2013 09:44 PM
awils961
Virginia Chapter
02-11-2011 05:15 AM
thumper869
10-27-2009 01:17 AM
Quick Reply: Spade connecter at starter is brittle
