general 70's frame perch question - Ford Truck Enthusiasts Forums
Old 05-29-2010, 09:21 AM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
67-79, despite minor mods in 77, the 2wd perches all appear the same. What I have are 351M/400 4x4 perches from 1979, and am wondering if these bolt in the same as the older 67-77 4x4's with FE's. I don't think they will, but just making sure. Secondly, if they don't, I'd like to see photos, if anyone has them, of the earlier FE 4x4 perches mounted and/or separated.
Old 06-20-2010, 01:16 AM
Bullitt390's Avatar
Bullitt390 Bullitt390 is online now
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Old 06-20-2010, 09:21 AM
havi's Avatar
Thanks Josh. Still looking for 4x4 pics of the FE perches installed. I guess ultimately, I just want to know if the 351M/400 perch from '79 will bolt into the same holes as a earlier 70's FE pickup. I can probably figure out the rest. This for an engine testing stand.
Old 06-20-2010, 09:37 AM
Bullitt390's Avatar
For an engine test stand I would just use some 2" square tubing with flat mounts to bolt directly to the engine block.
There are neat wood test stands on Youtube, not that I would go that route, but shows that not much is actually needed to start an engine out of a vehicle.
Do the 4X4 frames have two sets of holes like the 2WD versions? In the case of the FE perches they are mounted in the rear holes, whereas a straight-6 is bolted to the front holes. Same perch.
Do the 351M/400 and 460 share the same perches?
Josh
Old 06-20-2010, 10:28 AM
havi's Avatar
They do have two sets of holes, which when I swapped the 300 6 into my '79 Bronco, I used those other holes, IIRC however they wouldn't line up with the rear holes like an FE would? This engine test stand is going to be trailer mounted. The trailer is a truck frame (not a Ford), and is already near done. It's the standard 34" wide, so just bolting on the mounts would do the trick. If the 4x4 FE and 4x4 300-6 share the same perches, then I guess I could measure my '79 or '78 frame, and relocate the holes back where the V8 would normally go. Thinking out loud: They may even share two of the holes, but may need to drill separate holes for each perch when it comes time to swap between all of the Ford engines and their matching perches.
Old 06-20-2010, 02:31 PM
c.l.nye's Avatar
c.l.nye c.l.nye is offline
c.l.nye is starting off with a positive reputation.
if memory serves me, the 6 cyl mts use the rear shock mount bolts and the FE uses the rear most spring bucket bolts. I used my stock 6cyl mts and moved them forward one bolt whole.
Old 10-21-2010, 11:13 PM
havi's Avatar
FWIW, I finally found a free 2wd frame from mid 70's. Included is a 360 and C6.
Old 02-27-2011, 05:57 PM
havi's Avatar
And I found that the '77 and earlier frames have different hole locations than the '78/79, regardless of engine type.
Old 05-22-2011, 01:05 PM
havi's Avatar
Quote:
Being delivered tomorrow.
Just gonna pile all of my engines on the back 2/3rds of the frame and make a wagon out of it for now.
Motor mount perch issues. bsiebert 1973 - 1979 F-100 & Larger F-Series Trucks 11 06-18-2016 01:27 PM
Ford 300i6 perches 1979 f150 4wd (same as FE) julcan92 WTB - Parts & other 3 05-18-2014 11:08 PM
Engine perch advice for FE in 4x4 fomoco3904 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-16-2013 09:51 PM
70's engine swappers, here's a question havi Engine Swaps 28 04-18-2011 03:15 PM
Diference between 76 4x4 360 Motor mount perches and a 351W? jpb222 1973 - 1979 F-100 & Larger F-Series Trucks 2 06-06-2003 02:29 PM
Tags
1950, 1979, 239, 3006, 70s, 83, bolt, cid, custom, engine, ford, frame, stand, straig, truck, trucks, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
