5.4 3V into a '60 Ford panel. Anybody?
Old 05-20-2011, 08:35 AM
Kruse's Avatar
Kruse
Kruse is offline
I recently picked up a '60 Ford panel. The stock engine is a 223 6 cylinder which obviously won't be useable in today's world. I'm thinking of dropping in a 5.4 3 valve. Anybody done this? Are there any swap motor/tranny mounts available?
I suppose I could go with a 302 or 351 with RJM injection, but I'm keeping my options open. TIA.
Old 05-20-2011, 08:34 PM
Ziegelsteinfaust's Avatar
Ziegelsteinfaust
Ziegelsteinfaust is offline
Ford Racing I think it is has a drop in computer for the 3V's, and if I was going that route I would add the tranny controller too.
Yes they are a lot of money which is why I am staying away from them now, but you will have a better set-up then trying to use a C6 lets say.
Old 05-21-2011, 09:42 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
The ford racing harness is for the 4.6 3v OR the 5.4 3v Supercharged engines.
I also have a 5.4 3v non-supercharged to go into a 56 f100.
The ford harness is also manual tranny only. An auto tranny will require a separate controller, not from ford.
http://www.fordracingparts.com/downl...-463V_54SC.pdf
Sam
Old 05-21-2011, 10:42 AM
Kruse's Avatar
Kruse
Kruse is offline
Thanks for the replies. That's probably what I'm looking for.
I'm familiar with the Motosport products and this is probably the setup I'm looking for. I didn't realize it would need the dedicated accelerator pedal, but it makes sense.
I'll check it all out and make my decision then.
Old 05-21-2011, 10:52 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
when I talked to the Ford Racing tech support about the 5.4l 3v NON-supercharged engine, they said they had no clue if it would work. as they didn't try it.
and on the auto tranny they suggested places like Performance Automatic
Sam
max1fastboat
Modular V8 (4.6L, 5.4L)
03-20-2013 08:39 PM
Quill Gordon
1999 to 2016 Super Duty
26
06-05-2009 08:14 AM
kripfink
16
06-18-2008 04:10 PM
F250Rob
08-01-2004 10:15 PM
Quick Reply: 5.4 3V into a '60 Ford panel. Anybody?
