1988 ford pickup fuel pump problems - Ford Truck Enthusiasts Forums
Old 05-28-2010, 11:36 PM
bobby1979 bobby1979 is offline
bobby1979 is starting off with a positive reputation.
I have a 88' ford pickup with a 300 straight6 with duel tanks. Today i took it to put some gas in it it quit on me be fore i got there well i got it started went and filled it up both tanks got about a mile down the road it dies again will not start back up. i went and replaced the inline pump still not getting any fuel to come out i also checked the relay look fine also checked tank selector switch on dash it is sending power out to selected pump. what could it be PLEASE HELP!!!!
Old 05-29-2010, 06:59 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Are you saying with the High Pressure Fuel Pump on the frame unplugged you can not get any fuel out of the fuel line to the High Pressure Fuel Pump on the frame with either tank selected when you ground pin #6 of the EEC-Self Test plug and with the key on?
Do you hear either in tank boost pump run when it is selected and doing the above?
Gas tank pressure Jtsarby 1987 - 1996 F150 & Larger F-Series Trucks 5 05-06-2015 05:44 PM
1995 F-250 460 cid Fuel pump problem w6pea 1987 - 1996 F150 & Larger F-Series Trucks 8 05-21-2013 03:34 PM
Got a fuel pump/tank question Dr. Driveway 1987 - 1996 F150 & Larger F-Series Trucks 13 09-10-2012 01:52 PM
1990 Front Fuel tank problem old blue 90 1987 - 1996 F150 & Larger F-Series Trucks 5 07-04-2009 03:19 PM
Front tank doesn't work and overflowing ac700wildcat 1987 - 1996 F150 & Larger F-Series Trucks 27 11-26-2006 04:12 PM
Tags
150, 1987, 1988, f150, f250, ford, fuel, pick, pickup, problem, problems, pump, replace, system, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
