Transmission Controller for E40D
I quickly scanned over the instructions document (let me know if you need a copy) and I see my notes about the resistor but not where the instructions talk about needing it. I do remember I had to replace it just recently as it broke when I was moving the wires around. For my setup, which is E4OD, I cut the #3 wire from the PCM and inserted a 47k ohm, resistor. It can be either 1/2 or 1/4 watt. They said both would work. If I remember correctly, the resistor wasn't mentioned in the instructions and I learned about it on a phone call with Baumann a while ago.
could you please send the install instructions?
Let me know what you need.
Thanks
I emailed Bauman, they said to hook up the resistor, but if I do I have no tach, if I bypass the resistor and just hook up to the gray/black wire, I have tach and it seems to shift exactly the same, I don't recall getting any real hook up instructions with this, I got some paperwork that said green to blah blah, but nothing to indicate cutting or splicing in wires without cutting orginal wires, or exactly what to do, maybe thats why I have a some little problems. I need to program it again and change some shifts as well, get to about 50 mph and it downshifts instead of up shifting. etc..
Thanks
Thanks
But like I said before, the resistor isn't mentioned in the instructions. It was something I learned from a conversation. You will see my notes on page 10.
I am not sure what you mean by the tach. I didn't have a tach when I installed the trans controller and I just recently I added a factory tach in my instrument cluster, didn't notice a bit of difference.
thanks
I have uploaded the file here (too big to attach to this thread): http://www.filedropper.com/baumanntransmissioninstall
thanks
I hooked up the resistor(cut the gray/black wire) runs, shifts ok but no tach, with wire still cut and TCS(green wire ) hooked up have tach and shifts the same. Can you send me a copy of the install instructions? Its been like I said 8.5 years, and back then I found this confusing.
thanks
thanks
I have down loaded the files you provided thru the link, these are what I have. But I didn't see the "notes" you mentioned were on page ten.
Bauman really has poor instructions.
But thank you.
But thank you.
Yes, Baumann does have poor instructions. My notes are hand written, just indicating what size resistor and where it goes.
So I cut the Gray/ black wire going to the tranny from computer and hookup resistor to the gray/black wire going to the tranny? and then hook up green from controller to resistor?
and leave cut gray/black wire from computer taped off?
thanks
Thanks, I've tried to explain to Baumann, but , no luck so far.
thanks
thanks
Jasonhopkins
04-29-2016 08:22 PM
radjcw5
47
01-30-2012 10:37 PM
subsailor
10-27-2010 07:38 PM
controler, controller, diesel, e40d, e4od, ford, harness, loose, megasquirt, program, standalone, trans, transmission, wire, wiring
