2001 Expedition EB rear a/c not getting cold... - Ford Truck Enthusiasts Forums
Old 05-28-2010, 03:04 PM
Araltd Araltd is offline
Araltd is starting off with a positive reputation.
So I have a 2001 Expedition eddie bauer, and the rear a/c doesn't seem to get cold. The front get's cold -but not the rear a/c.
Is the rear a/c a complete separate system? could it need charging? and if so, where is the low side "port" ??? I couldn't find it anywhere.
I'm reading about blender doors, etc... I HAVE NO CLUE. Someone point me in a direction to start, and I can go from there.
Old 05-28-2010, 09:30 PM
lsrx101 lsrx101 is offline
lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.lsrx101 has a very good reputation on FTE.
The rear system is not separate. The front and rear systems share the compressor and condenser. With a low refrigerant charge, it's usually the front that wheezes out first.
Without the system pressures it's only a guess, but I think you have a blend door actuator issue in the rear unit. It's common. The evaporator is getting cold, but the door never directs air over it for cooling.
Need your opinion on 00 Exp a/c clutch no voltage? 1998Ranger25L153CID 1997-2006 Expedition & Navigator 1 03-16-2016 05:18 AM
08 Expedition EL - Front A/C Issue Bloody-J 2007 - 2014 Expedition & Navigator 4 08-12-2015 10:33 PM
Max a/c cutting out Byf619 1997-2006 Expedition & Navigator 25 05-04-2012 03:06 PM
'04 Expedition rear a/c click noise ToothDoc 1997-2006 Expedition & Navigator 12 05-16-2006 04:13 PM
Expedition Rear AC not working chaneyb Cooling, Heating, Ventilation & A/C 1 06-21-2005 03:42 PM
Tags
2001, 2003, ac, blender, charging, cold, door, expedition, ford, front, location, low, navigator, rear, refrigerant, side, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
