406/427 exhaust manifolds - Ford Truck Enthusiasts Forums
Old 02-03-2003, 06:17 PM
MKPJ1 MKPJ1 is offline
MKPJ1 is starting off with a positive reputation.
I would love to have a pair of 406/427 bananas for my 390
F-100. Is this a possibility. Seems like the flow would be much better than the logs and better for heat control/loud headers. My Bronco is loud (sets off car alarms) and I would like my F100 to walk softly and carry a big stick. I'm getting old. What do you all think?
Ken
68 F100 390
74 Bronco 351W
Old 02-04-2003, 09:21 AM
390fe 390fe is offline
390fe is starting off with a positive reputation.
They can be found, if you're willing to pay the price. Look in classifieds catering to Galaxies, and in eBay. You may need to notch the frame rail on the passenger side, but they should fit.
Old 02-04-2003, 10:42 AM
William William is offline
William is gaining momentum as a positive member of FTE.
Right side frame rail clearence is an issue but better than notching is to heat it and roll it up to form a lip. I wish I had a set of these as well. You would think someone would make them aftermarket!
William in Atlanta
Old 02-05-2003, 06:06 PM
Thanks for the reply's. William, I have read several of your other posts on your exhaust set up. Are you going to use the standard logs? They seem awful. I hope to find a pair of these cast iron 427 jobs. If I can't, I guess I will look into some tri-y's with ceramic coating for heat control. Seems like an awful lot of money for 15 more horses? There is a lot to be said for heat control and piece and quiet too.
Ken
Old 02-05-2003, 08:24 PM
67 428 Fairlane Ranchero 67 428 Fairlane Ranchero is offline
67 428 Fairlane Ranchero is new and has a neutral reputation at this point.
Ken
68 F100 390
74 Bronco 351W
Hey Ken, I think that we are all getting old. Some of us just don't want to admit it.
Old 02-06-2003, 10:32 AM
I am currently using stock 2 1/4 inch log manifolds. Exhaust system is 2 1/4 inch dual to a Flowmaster 70 series with single 3 inch out the back behind the right rear tire. This combination is pleasantly quiet, but drones just a bit. I plan to add an equalizer tube under the oil pan soon hoping the drone noise improves. I believe the cast iron headers from 406/427 would really be a great improvement but I think they are to expensive and I do not spin this truck much more than 3500 RPM. I am also a member of the "old Timers group". Hate change, technology, cheap beer and progress. Firmly stuck in the 60s and happy there!
William in Atlanta
Old 02-09-2003, 01:23 AM
89F150FE390 89F150FE390 is offline
89F150FE390 is starting off with a positive reputation.
Cool 406/427 exhaust manifolds
Just a suggestion, you could try a set of industrial manifolds off a 330/361/391. They flow about as good as shortys but aren't loud. Only problem is your pipes attach to the center. I built motor mounts to make them fit.
428 or 406 heads on 390..worth it? 71 Muddbugg FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 1 01-10-2005 04:53 AM
Fe differances in Bellhousing ? jav409 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 09-23-2004 09:04 PM
Casting #'s (406?) 390fourby FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 09-05-2004 12:31 AM
What forums do you read? Andysutt General NON-Automotive Conversation 17 10-11-2003 07:57 AM
will 406 cast exhaust manifold fit on my 390 in pickup gtex FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 09-19-2001 11:33 PM
Tags
406, 406427, 427, apair, cast, exaust, exhaust, find, ford, iron, manafold, manfold, manifold, manifolds, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
