have you changed your ECM ?
Old 05-28-2010, 10:57 AM
jpf's Avatar
jpf
jpf is offline
would like to ask anyone who has changed their ECM, why did you change it?
after you changed the ECM did your truck run properly?
or after you changed it did you find your problem wasn't the ECM?
if your problem wasn't the ECM did you find what it was?
as you can tell I am thinking of changing mine but would like to hear how that worked out for others?
Old 05-29-2010, 02:29 PM
mustangski's Avatar
mustangski
mustangski is offline
I had mine changed at the dealer a couple of years ago, the tuner I used fried it and my instrument cluster. The truck ran the same it did before I fried it, have 50,000 on it now and still no problem. I do know that you have to match the numbers on the ECM, I am not completely sure the whole story on it whether it goes by year, engine, trans, or what. Cost me a good amount of money though I can tell you that.
Old 05-29-2010, 06:22 PM
Greg B's Avatar
Greg B
Greg B is offline
I have not had to change out the ECM, but you will have to get it flashed if you do change it out so it'll run right. They'll retrieve the data from your ECM and transfer it to the new one.
Rarely is the ECM a problem, though. If one retrieves the trouble codes and follows the diagnostic routine for the code per the Powertrain and Emissions manual, you'll find the problem.
Jake9473
13
11-07-2014 09:34 AM
antiqueynot
1983 - 2012 Ranger & B-Series
25
04-17-2012 11:31 AM
gurrola
03-31-2011 11:41 PM
ewturtle
08-17-2008 10:08 PM
Quick Reply: have you changed your ECM ?
