Ignition Key won't turn - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-28-2010, 10:22 AM
GW09F350 GW09F350 is offline
GW09F350 has a good reputation on FTE.GW09F350 has a good reputation on FTE.
I have a 09 F350 Lariat SuperCrew SRW 4x4, Last night the ignition key would not turn at all. Tried wiggling the steering wheel, (noticed it wasn't locked), wiggled the shift lever (auto trans). After about an hour of "beatn and jiggling, it just started working!?? I have no idea what caused this, neither does my dealers service dept. It's working fine now. Has anyone had this happen to them?
Old 05-28-2010, 11:22 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
Welcome to FTE.
Could it be the key is getting worn out?
Old 05-28-2010, 11:34 AM
I don't think so, I bought the truck new in Nov. 09, and it only has 11k miles. Service Mgr. just told me they couldn't duplicate the problem and Ford has no reports on what could cause it. So I guess I'll just drive it till it does it again.
Old 05-28-2010, 11:44 AM
Good luck. I hope it only does this when you are at home.
Old 05-28-2010, 01:52 PM
ChargersFanInCO ChargersFanInCO is offline
ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.ChargersFanInCO has a good reputation on FTE.
Quote:
Unlike the Ford Focus that would leave you sitting wherever you shut it off at last in the 00-01 years...lol
Old 05-28-2010, 01:56 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
I had similar issues on cars with 200,000 miles on them, but pretty new truck?
What helped me was spraying WD40 inside the lock with the small hose, than inserting and removing the key several times -wiping it at each time. That removed quite some dirt from the cylinder.
Also start using second key as they wear out the blades and cylinder over the time to the point when never used key will not work.
Old 05-28-2010, 02:26 PM
That is a great tip. Thanks.
Old 05-28-2010, 03:00 PM
Thanks for the input, dealership sprayed graphite based lube inside ignition switch. They said that it's possible the tumblers inside the switch could have been sticking. I hope it works, because "ChargersFan" is right, if it does it again I'm stuck. Thank God for roadside assistance and cell phones. This is the first problem I've had with this truck, I really love it, and it pulls my 13k lb. 35' 5th wheel like it's a lawn cart.
Old 06-21-2010, 10:19 AM
Swinger Vic Swinger Vic is offline
Swinger Vic is starting off with a positive reputation.
Ignition cylinder is locked, need help fast
Howdy,
2006 F250 Lariat 6.0 auto, last year I replaced the ignition cylinder due to a break in.
Wheel is locked, ignition wont turn, ignition cylinder will not slide out and release button will not press in. I have damaged the cylinder trying to get it out or while trying to turn it.
Any ideas? I will drill the release button tonight trying to get the cylinder out.
Old 02-08-2015, 12:52 PM
DRYWALLJOE DRYWALLJOE is offline
DRYWALLJOE is starting off with a positive reputation.
I just want to thank you guys after reading all the post i was able to find the problem with my 06 f150 ! the ignition would not turn to the run position. i shot a bunch of free all in it and it started working .thanks again
Old 02-09-2015, 11:09 AM
speakerfritz's Avatar
speakerfritz speakerfritz is offline
speakerfritz is gaining momentum as a positive member of FTE.speakerfritz is gaining momentum as a positive member of FTE.
on a few fords I have owned in the truck class, if the wheels are not straight, and the vehicle was parked on a slope, the key would not turn unless you turned the steering wheel back to center until the key clicked.
Old 02-10-2015, 02:41 PM
droldsmorland's Avatar
droldsmorland droldsmorland is offline
droldsmorland has a good reputation on FTE.droldsmorland has a good reputation on FTE.
Quote:
Ditto speak! Beat me to it. Try rotating the steering wheel one way or the other while rotating the key and see if that solves the problem. People have been experiencing this phenomena since the late 60s when the steering wheel lock function came into vogue Detroit wide.
my ignition isn't wanting to turn fscarrow 1999 - 2003 7.3L Power Stroke Diesel 8 08-15-2014 07:00 PM
Ignition switch issues and no steering wheel lock bigcountry1009 1999 to 2016 Super Duty 0 05-03-2014 10:35 AM
00 7.3 F250 SD Diesel Key won't turn the ignition love2truck 1999 - 2003 7.3L Power Stroke Diesel 4 09-05-2013 10:05 PM
Ignition Lock Cylinder Doran 1997 - 2003 F150 5 12-27-2010 06:26 PM
Key ignition won't stop "dinging"!! Wide Open Throttle 1999 - 2003 7.3L Power Stroke Diesel 8 01-04-2010 12:04 PM
Tags
1996, 1997, 2004, 8000, econoline, expedition, explorer, f250, ford, ignition, key, keys, truck, turn, wearing, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
