Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Maryland Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Maryland Chapter Join Chapter, Leader: jr32560
  #1 (permalink)
Old 05-28-2010, 12:23 AM
80351's Avatar
80351 80351 is offline
Garage is empty, add now
80351 is a splendid one to behold80351 is a splendid one to behold80351 is a splendid one to behold80351 is a splendid one to behold80351 is a splendid one to behold80351 is a splendid one to behold
Hey Charlie, whats that fix?????????
Saved the pics you sent now just tell me how to fix that thing I don't think there is a Ford dealer close by
__________________
Dave
92 F150
Chapter Member
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting"Holy Crap, What a Ride" R.I.P.Marty, Jason
  #2 (permalink)
Old 05-28-2010, 04:51 AM
dustybumpers's Avatar
dustybumpers dustybumpers is online now
Almost Normal
1995 Ford F-150
dustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputationdustybumpers has a superb reputation
that part HAS to be instaled by ford, it is a recall, and needs to be put in to keep your car from catching fire even when parked, but it won't make the cruise work if not working now. check to see if the harness is hooked up,or burned, the linkage is hooked up on the throttle body, etc. do you have a airbag code flashing? does your horn work?
__________________
Charlie slackmaster #26 "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
"If more sane people were armed, the crazy people would get off fewer shots."
"Some people are alive because it's illegal to shoot them"
  #3 (permalink)
Old 05-31-2010, 04:55 PM
80351's Avatar
Quote:
No airbag light and no the horn is not working
__________________
Dave
92 F150
Chapter Member
  #4 (permalink)
Old 05-31-2010, 05:02 PM
Almost Normal
1995 Ford F-150
Air Bag Sliding Contact AKA Clockspring.
WARNING:
THE ELECTRICAL CIRCUIT FOR AIR BAG DEPLOYMENT IS POWERED DIRECTLY FROM THE BATTERY AND BACKUP POWER SUPPLY. TO AVOID ACCIDENTAL DEPLOYMENT AND POSSIBLE PERSONAL INJURY, THE BATTERY POSITIVE CABLE MUST BE DISCONNECTED FOR A MINIMUM OF ONE MINUTE BEFORE BEGINNING WORK TO DE-ENERGIZE THE BACKUP POWER SUPPLY.
Removal
1. CAUTION: Be sure air bag sliding contact internal lock is engaged. Hub should not turn more than 45 degrees in either direction.
Make sure that vehicle's front wheels (1007) are in the straight-ahead position and steering column shaft alignment mark is at the 12 o'clock position.
2. Disconnect battery to starter relay cable (14300) for at least one minute to let the air bag backup power supply discharge.
3. Remove steering wheel (3600).
4. Remove steering column upper and lower steering column shrouds (3530).
5. Disconnect three air bag sliding contact electrical connectors from main wiring (14401) at steering column bend bracket.
6. Using door trim removal tool, remove air bag sliding contact electrical connectors from bend bracket.
7. CAUTION: Do not remove wire harness clips from wire bundle.
Using door trim removal tool, disconnect two wire harness clips from column.
8. Remove key warning buzzer contact and anti-theft contact from ignition lock cylinder pocket of steering column tube flange (3511).
9. Remove air bag sliding contact (14A664) by pushing snap back at 6 o'clock position first, then 3 o'clock position, then 12 o'clock position and remove from steering shaft.
Click the image to open in full size.
Installation
1. Make sure that vehicle's front wheels are in the straight-ahead position and steering column shaft alignment mark is at the 12 o'clock position.
2. Align air bag sliding contact to column shaft and mounting tabs and slide onto shaft. Push on air bag sliding contact to snap three tabs onto steering column tube flange.
3. Install air bag sliding contact cable clips into holes in steering column.
4. Install air bag sliding contact connector retainers into provided holes in steering column bend bracket.
5. Plug main wiring harness connectors into three air bag sliding contact connectors.
6. Install key warning buzzer contact and anti-theft contact into ignition lock cylinder pocket in steering column tube flange. Make sure contacts do not slip out of ignition lock cylinder pocket.
7. Install upper and lower steering column shrouds.
8. Install steering wheel.
9. NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 10 miles or more to relearn the strategy.
Connect battery to starter relay cable.
10. Verify air bag warning indicator operation.
__________________
  #5 (permalink)
Old 05-31-2010, 05:11 PM
80351's Avatar
Thanks Charlie I do have to do that maybe, I don't plan on havtng it much longer so just might trash the car
__________________
Dave
92 F150
Chapter Member
  #6 (permalink)
Old 05-31-2010, 05:15 PM
Almost Normal
1995 Ford F-150
Quote:
keep the drive train, 4.6 is a bad a$$ powerplant. would make a great rod. plus the disc brakes on the 8.8 rear.it's got a project written all over it. mabe a low rider 4x2 bronco II?
__________________
  #7 (permalink)
Old 05-31-2010, 05:23 PM
80351's Avatar
motor is shot and no place to keep it and no means of getting it out. LOWRIDER aint nothin I own riden low but would love to have the rear isc on the rear of the BII
__________________
Dave
92 F150
Chapter Member
Tags
1960, 2003, alignment, antitheft, broken, clockspring, column, disassemble, f100, f350, fix, flange, ford, installation, series, steering, tube, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
