Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 05-27-2010, 10:23 PM
dbtx dbtx is offline
Garage is empty, add now
dbtx is starting off with a positive reputation.
Carseat/Headrest interference and removal
We needed to turn our daughters car seat from rear facing to front facing this week, and were very disappointed to see that the top of the car seat hit the head rest before the back of the car seat was flush with the seat. The only solution was to remove the head rest. I spent some time with google and found that the procedure is very simple. I figured that I would repost it here, as I'm certain others will find it useful at some point.
The head rests are held in with simple wire clips. All you need to do is push the seat material down around the plastic post mount and you'll see the ends of the clip. Simply take a pair of needle nose pliers and push the clip toward the back of the seat and it will come off. Be careful not to push it back into the seat material where you can't get it out once it's off. I came very close to that happening! After you take both sides off, the head rest simply slides right up and out.
Anyway, I wanted to give back a little to the forum since I've learned SO much here over the years.
Doug
__________________
2008 Expedition EL 4x2 with heavy duty tow package
2007 F150 XLT SCrew 4.6L Black with Chrome package
Mods: Katzkin Dark Charcoal Leather Interior, Rubber Bed Mat
2005 Excursion 4x4 Limited V10 (traded on the Expy)
Mods: Helwig Rear Sway Bar
  #2 (permalink)
Old 05-28-2010, 12:16 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
pictures? I almost did this for my twins. but then threw them on the third row
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #3 (permalink)
Old 05-28-2010, 06:40 AM
welfarewagon welfarewagon is offline
welfarewagon is starting off with a positive reputation.
Quote:
You should never throw your kids they could get hurt,
  #4 (permalink)
Old 05-28-2010, 09:54 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
they bounce quite excellently
__________________
  #5 (permalink)
Old 05-29-2010, 09:09 PM
CarbonClear CarbonClear is offline
CarbonClear is starting off with a positive reputation.
__________________
2012 Toyota Tundra Double Cab 4x4
2007 Ford Expedtion EB
2006 Porsche Cayenne S
2004 Honda Crv
2003 Ford F350 XLT, 7.3 Diesel 4x4 (Sold)
2001 Porsche Carrera Cab
  #6 (permalink)
Old 03-31-2011, 10:29 AM
SickPup404 SickPup404 is offline
SickPup404 is starting off with a positive reputation.
Doh! Saw this a month late! Found the clip the hard way.
Also, once you remove the headrest, you can put the clip back on so when the car seat comes out, it will lock back in place!
  #7 (permalink)
Old 03-31-2011, 11:03 AM
Hemlock10's Avatar
Hemlock10 Hemlock10 is offline
2006 Ford F-350
Hemlock10 is starting off with a positive reputation.
Do you have the bench seat in the back? I'm wondering how different the head rests are from what I have.
I have the captains and never had to remove the head rests. I just pull the tilt lever on the rest to get it to lean forward, slide the rear anchor through the opening between the rest and the seat and then lock it back in the up position so that it doesn't interfere with the child seat.
I would have thought that Ford would make it so that you didn't have to remove the rests just to put the rear anchor in place. I would be very interested to learn that they make it difficult to secure your kids properly.
  #8 (permalink)
Old 03-31-2011, 11:08 AM
I've got the 2nd row captains - the ones that the headrest folds for 3rd row entry and also "kneel" for cargo mode.
We use the Britax Boulevard and when we turned it to front-facing, the top hits the captains seat headrest and can't be latched in place level with the ground. The rear anchor will go fin, but the britax seat is tall...
  #9 (permalink)
Old 03-31-2011, 11:20 AM
Hemlock10's Avatar
2006 Ford F-350
Oh! Sorry, I misunderstood. That makes more sense now.
  #10 (permalink)
Old 06-14-2011, 11:52 AM
cstanley44's Avatar
cstanley44 cstanley44 is offline
2008 Ford Expedition
cstanley44 is gaining momentum as a positive member of FTE.
Thank you!
I just purchased an 08 Expedition EL
One of the head rests on the 3rd row, was missing the release strap so I could not completely fold the seats for cargo.
The dealer where I bought it has ordered me a new pull strap.
So I decided to remove the head rests for now and I could not figure it out!
But thanks to this site I did remove it. (didnt loose the c-clips either )
And the best part is, once I had it off and upside down, I could see the strap was just pushed up into the slot! I hooked it out and it works great!
  #11 (permalink)
Old 06-14-2011, 12:08 PM
Yup, great isn't it! Very helpful group of people here!
Tags
2007, 2010, expedition, f150, f250, ford, head, head rest carseat, headrest, headrests, removal, remove, rest, seat, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
