TEMPERATURE GAUGE SENSOR LOCATION - Ford Truck Enthusiasts Forums
Old 05-27-2010, 10:43 PM
claycomotrucks1991's Avatar
claycomotrucks1991 claycomotrucks1991 is offline
claycomotrucks1991 is starting off with a positive reputation.
I have a 1996 4.0L V-6, the temp gauge is not working. I have the temp sensor under the hood for replacement but can't find where it goes. Part number F1SZ-10884-A.
Old 05-28-2010, 07:55 AM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
There are two different 4.0L V6 engines, but fortunately the description of location of the Coolant Temperature Sender is the same for both. Per the 1998 Factory Service Manual (your 1996 should be similar) the location is the center of engine compartment, behind alternator bracket.
If you ordered the Coolant Temperature Sensor, you probably received the wrong part. The sensor is for the PCM, the sender is for the gauge.
-Rod
Old 05-29-2010, 05:04 PM
I looked today to find the temp gauge sender and it is not at that location. What is there is a bypass kit adapter that was installed years ago on a recall to help the engine warm up faster in the winter or colder months. Still can't find the temp sender where they moved it I don't know very few people at ford can even find this recall in the computer or the parts for it sense it goes back to around 1999. Need help on this on bad need to find sender.
Old 05-31-2010, 09:36 PM
shorod's Avatar
Well, you know it needs to be mounted in a coolant passage, and since heat rises they'll typically be high on the engine block/head. I guess if it's not near the thermostat housing like the factory service manual says it should be, it's probably in that area somewhere. Fortunately there are only a finite number of areas where it could be.
-Rod
Computer temp sensor for E4OD? LeoJr Clutch, Transmission, Differential, Axle & Transfer Case 4 07-07-2016 08:36 AM
Temp guage Whynotgman 1978 - 1996 Big Bronco 3 06-16-2016 06:04 PM
temp gauge problem gjwniflst Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 2 07-16-2013 09:13 PM
water temp sensor and oil temp sensor JMAN21 1999 to 2016 Super Duty 5 07-20-2011 01:41 PM
94 bronco temp sensor bh70116 1978 - 1996 Big Bronco 3 08-29-2010 07:32 PM
Tags
1995, 54l, 73, diesel, engine, explorer, ford, gauge, heat, location, sender, sensor, temp, temperature, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
