Best grit for smoothing door handles?
If you have plastic texture, cut it down with 180 and then after the grain is almost completely gone bump up to 220 and then 320. Use a good adhesion promoter, then prime the handles. Put a final sand of 320g on the primed handles and they will be ready for final prep and paint. Don't go above 320-400g, as the paint will need a mechanical adhesion to bit on to properly. Good luck!
jdstudski
08-08-2013 05:57 PM
Vacationtime247
12-03-2010 09:28 PM
