E350 tow pkg and rear gear questions - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 05-27-2010, 05:40 PM
rowekmr rowekmr is offline
rowekmr is gaining momentum as a positive member of FTE.rowekmr is gaining momentum as a positive member of FTE.
Hello
I just got this 98 E350 Chateau passenger van with the V-10 and just assumed it had a towing package. Today I looked and saw what appeared to be a trans cooler mounted in front of the radiator but I wanted to verify which tow package it has (std or hd?). It pulled my TT and I noticed that the rpms were much lower in OD at highway speeds (by sound no tach) than my Ex with the 4.30 so I wanted to know how to tell which rear gear ratio it had off of the VIN or gear code. The VIN is 1FMNE31S7WHA15450. There is a second bar of codes and under Axle is says 34. Where can I post to get an OASIS for this van?
Also does anyone know the approx empty weight of a E350 with factory seating (4 capts 1 bench) and options?
Thanks
Joe
Old 05-27-2010, 11:35 PM
rebocardo rebocardo is offline
rebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud ofrebocardo has much to be proud of
Not sure, but, I think that is standard on the V-10, unlike earlier years.
Old 05-28-2010, 01:00 PM
sandi_k sandi_k is offline
sandi_k is starting off with a positive reputation.
Gearing on the 34 axle is 3.73, and it's a not Limited Slip.
There should be a sticker on the driver side door that gives additional info.
Sandi
Old 05-28-2010, 01:08 PM
If you Google axle codes Ford E350, you get this...
From the '04 Service Manual
AXLE CODES
19 3.55 ratio, non-limited slip (Visteon)
22 4.10 ratio, non-limited slip (Dana)
24 3.73 ratio, non-limited slip (Dana)
32 4.10 ratio, non-limited slip (Dana)
34 3.73 ratio, non-limited slip (Dana)
35 4.09 ratio, non-limited slip (Dana)
39 3.55 ratio, non-limited slip (Dana)
52 4.10 ratio, non-limited slip (Dana), dual rear wheels
56 4.10 ratio, non-limited slip (Dana)
82 4.10 ratio, non-limited slip (Dana)
83 4.56 ratio, non-limited slip (Dana)
84 4.88 ratio, non-limited slip (Dana)
85 5.38 ratio, non-limited slip (Dana)
B4 3.73 ratio, limited slip (Dana)
C2 4.10 ratio, limited slip (Dana)
B2 4.10 ratio, limited slip (Dana)
C4 3.73 ratio, limited slip (Dana)
C5 4.09 ratio, limited slip (Dana)
C9 3.55 ratio, limited slip (Dana)
E2 4.10 ratio, limited slip (Dana), dual rear wheels
E6 4.10 ratio, limited slip (Dana)
F2 4.10 ratio, limited slip (Dana), dual rear wheels
F3 4.56 ratio, limited slip (Dana), dual rear wheels
G4 4.88 ratio, limited slip (Dana)
G5 5.38 ratio, limited slip (Dana)
H9 3.55 ratio, limited slip (Visteon)
TRANSMISSION CODES
5 Four-speed automatic overdrive (4R75W)
B Five-speed automatic overdrive (5R110/Hi-Torque), diesel
E Four-speed automatic overdrive (4R100)
U Four-speed automatic overdrive (4R70W)
Vin info 53Tow 1999 to 2016 Super Duty 12 10-03-2014 10:10 AM
2010 E-350 Trailer Towing Wiring GeoMiklas 1968-2013 Full Size Vans 5 08-17-2014 11:51 PM
whats the best ring gear and pinion company? andrewzx92000 1968-2013 Full Size Vans 3 03-25-2011 07:29 AM
Upgrading Our Towing Van - E250 or E350? sandi_k 1968-2013 Full Size Vans 25 05-21-2010 07:41 PM
2003 E350 12 pass. towing package ? BRMAN 1968-2013 Full Size Vans 6 03-26-2004 04:58 PM
Tags
2006, 2007, 350, axle, c4, codes, e350, ford, kit, package, passenger, tow, towing, trailer, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
