Gear change in F450? - Ford Truck Enthusiasts Forums
Old 05-27-2010, 04:23 PM
texasjack texasjack is offline
texasjack is starting off with a positive reputation.
My 1990 F450 5 spd, has a dana 80 with 513's in it , and let me tell you, its time to change that ratio. I'm thinking 4.10? The truck weighs 7000 lbs .Would 373's require a new carrier?
Any sources for the ring and pinion? thanks clan for the infor!
Old 05-27-2010, 04:52 PM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
This may help you....... http://www2.dana.com/pdf/5332.pdf
Old 05-27-2010, 05:03 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
5.13!
Wanna haul my house?
Old 05-27-2010, 05:51 PM
Njdub Njdub is offline
Njdub is starting off with a positive reputation.
Did that thing come stock with 5.13s??!??
Old 05-27-2010, 06:31 PM
All F450's either came with 4.56, 4.63 or 5.13
So yes it's stock.
Old 05-27-2010, 06:42 PM
Oh yeah I guess you'd need them for heavy towing just seems high.
Old 05-27-2010, 09:33 PM
Yes, its very high, and not much good for hwy, which is what there is alot of here.
410's would be better and still let me haul, gears seem pricey...
Old 05-27-2010, 09:35 PM
johnboggs21's Avatar
johnboggs21 johnboggs21 is offline
johnboggs21 is starting off with a positive reputation.
hell 3.55s are fine unless you are moving ungodly heavy loads.
Old 05-27-2010, 10:49 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is online now
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
thats what f450's are made for though.hauling,and hauling like they mean it.
those gears are good for that truck imho.i wouldn't change them.
if you find your not hauling the loads that require some low gears,perhaps you don't need an f450?
she's going to feel doggy with 4:10's with a real load on her.what are you hauling mostly? rock/dirt/gravel etc or? hows the truck used?
the cheapest way would be to score a whole rear axle i should think from the salvage yard.......using John's info,look for one with a set of 4.56 gears.any higher than that,then your hauling stuff that a pickup truck could haul,and a f450 is the incorrect rig to have imho.
f450's are not pickups keep in mind.if your getting behind the wheel to drive it anywhere without the intent to make $ with it,you bought the wrong rig or have loads of extra $ just to burn in fuel.
Old 05-27-2010, 11:00 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
Gawd I wish I could remember that riddle ... Something like:
High is low and low is slow, low is high and high is fast (and I forget the rest, something about "low is quicker ... blah blah")
The point is the higher the number the lower the ratio, slower top end but with more grunt, so the higher number is considered a lower gear!
-Enjoy
fh : )_~
Old 10-10-2011, 01:02 PM
crazykooter crazykooter is offline
crazykooter is starting off with a positive reputation.
I know this post is a little old but I have been pondering if I should change gears in my truck. Its the same axle as this guys cept I have 4.56 gears.
I made a custom flat bed on it which I use to haul my toyota rock crawler.
My truck is only bout 6000 pounds empty and 8500 pounds loaded.
The main problem I have with my gear ratio is on the freeway. For me to do 70 mph I am turning 2750 rpms. Which is brutal on the fuel mileage.
Also when I need to climb a hill on the freeway, like going over the summit on I80 I have to drop out of 4th gear. In 3rd gear for me to do 45 mphs I have to turn damn near 3k. Diesels can run at this rpm ok but it really heats my engine up more then I like and it clogs up traffic.
I think if I had 4.10s in the rear I would be able to stay out of overdrive on the hills and be able to do atleast 55 without running my engine so hard.
The sucky part of it is I cant find gears for this old of a axle.
I am gonna 2008 dana 80 with 40k, I think its 4.13 gears for 400 bucks.
Seams like the best way to go.
Other option would be to swap my 16" rims for 19.5" rims and tires. I think this would make freeway driving much better but the 19.5 tires are a lot more $$$.
Sorry for the long post.
It looks like crap now but ive been going thru everything and body work is almost done, so painting is near.
Old 10-10-2011, 01:46 PM
GHeTTo JOe's Avatar
GHeTTo JOe GHeTTo JOe is offline
GHeTTo JOe is starting off with a positive reputation.
then you would need different rims for the bolt pattern?
Old 10-10-2011, 05:59 PM
I have 10 lugs on my current dana 80. Did they change the lug pattern?
Old 10-11-2011, 11:18 AM
Phy's Avatar
Phy Phy is online now
Phy has a good reputation on FTE.Phy has a good reputation on FTE.
Yeah, the F-Superdutys have 10 lugs on a 7.25" bolt circle. The later 10-lug pattern is different...
The hubs might interchange, though...
Old 10-11-2011, 04:37 PM
Ok bummer guess ill try and find out what year of dana 80's have same lug pattern.
Sucks since I can do the ring and pinion swap myself but they dont sell any gears for this year of axle.
Thanks for the help.
2017 F 450 fuel mileage Dy17 2017 Super Duty 27 01-27-2017 03:11 PM
08 450 Rear Brakes & Rotors Superduty450 1999 to 2016 Super Duty 6 07-04-2014 08:34 AM
F-450/F-Superduty is considered a ???? 7DF250 1987 - 1996 F150 & Larger F-Series Trucks 3 05-04-2011 11:50 AM
F450 clutch install Ryand2000 1999 to 2016 Super Duty 2 11-08-2009 09:56 AM
f 450 4x4 conversion slenherr 1999 to 2016 Super Duty 5 07-10-2007 01:42 PM
Tags
1989, 1990, 410, axle, body, f450, ford, gear, gears, hauling, pinion, ratios, rear, ring, stake, zf5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
