Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
- How to Flush Radiator
Step by step instructions for do-it-yourself repairs
Gooch's Radiator/Engine Backflush Procedure and Coolant Information
#107
The following reason for not using ELC in an Early '99 7.3L PSD applies to your rig too.
Stewart
The following information from Gooch pertains to why ELC's are not recommended for use in early '99 7.3L PSD's.
Mostly it's the injector cups. International, who made the engine, found some compatibility issues with the older injector cup material, sensors, front cover, seals, gaskets, o-rings, and probably some other stuff when using coolants that contained organic acid technology (OAT). Coolants like ELC's (usually Red) and G-05 (usually Gold) will have these OAT's. Conventional coolants (usually Green) will not.
So International revised those components on all 2/2/99-up build engines (SN 940614-up), and began recommending and factory filling with HD ELC coolants mid-year 2000. Never looked back.
You could use HD ELC's in the older engines, but you run the risk of having to replace the cups and maybe some other stuff. I always try to recommend conventional coolant meeting ASTM D4985 with SCA or a pre-charged conventional coolant meeting ASTM D6210 for those. But it's your call, and some owners use the ELC in their older engine successfully. For the 2/2/99-up builds I would highly recommend upgrading to HD ELC.
BTW, if you need to check the build date of your engine, you can find it on the valve-cover tag (driver's side), or stamped on a machined surface on the underside of the engine, behind the oil filter and just ahead of the bell-housing cover. You may need to wire brush/clean it to read it.
Stewart
Stewart
#109
#111
If you wanna call the CAT dealer over here and find out if they have it, I can pick it up and ship it for you. Remember, they are PST.
Quinn CAT Oxnard: 805-485-2171
Dont know how feasible it would be for you, but if all else fails..
#112
I picked some Fleetrite ELC up at the local International dealer the other day. $19.55 a gallon.
A tip to add to this writeup.....If you're replacing the heater hoses and don't have the fancy release tool, just break the skinny part of the old connector off and pull the hose off. Its so much easier then trying to get those stupid clips to release.
And make sure all the hose connections are clean and smooth! I had to drain all the new coolant out after the new lower hose started leaking at the water pump.
#113
AJ
#114
#115
Yeah Im gonna take back the ELC I bought (glad i found the 2/99 thing today) and just get some CAT DEAC from the same place. That sound ok?
http://www.cat.com/cda/files/1386261/7/PEHP9554-03.pdf
#116
#117
Well I bought 5 of them so 20 aint gonna do it. The folks at Johnson machinery where I bought it are super cool and Im sure if I'm keeping one of them form my excision and returning 4 of them for 5 DEACs they will be cool about it. I might as well pick up a CAT SCA test kit while Im at it and some CAT SCA which i will probably need to put in the system in a year.
AJ
AJ
#118
My coolant has been low for a while now and so i went down to the napa without reading this thread first. I read the first few posts but wanted to know if anything has changed as far as the concentrate being preferable over the 50/50 stuff.
I bout 8 gallons of the 50/50 solution today and if I should take it back I will. Keep in mind i have an E99 so it is the green stuff.
I want to be all the way ready for winter so let me know!
Thanks
Thanks
#119
Thanks
Thanks
#120
Thanks
Thanks
