Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
- How to Flush Radiator
Step by step instructions for do-it-yourself repairs
Gooch's Radiator/Engine Backflush Procedure and Coolant Information
#61
Stewart,
It's a 2001 F250 CCLB Lariat 4x4 PSD. If I understood all of the Gooch-sourced information you provided, the Chevron Delo ELC will be fine - correct? About $20/gallon in Anchorage. I guess that's in the ballpark for cost?
By the way, thanks for posting all of this 7.3L PSD coolant information in one Thread. Very nice!
#62
Yep, 2001 is good to go and yeah, that's why I asked.
Glad everything in one thread helps. I'd not seen that anywhere else, only Gooch's flush procedure. Also, I thought it would be nice for FTE to have their own "Gooch" thread so people don't have to post links to other boards.
Plus, after looking at all the other boards I have bookmarked (but rarely visit), this is the first thread on the 'net to have a compilation of all the Gooch info!
Stewart
Stewart
#63
#64
ASTM D-4985 means it's an ethylene glycol coolant for diesel engines.
ASTM-D4985 is the specification for low silicate ethylene glycol base engine coolant for engines requiring a pre-charge of Supplemental Coolant Additive (SCA).
I would read that to mean it's the traditional "green" coolant, but the "low silicate" portion of the spec sheet and your post stating it's good for 5 years/150K miles makes me wonder if it's a Hybrid-Organic Acid Technology (H-OAT) Extended Life Coolant, otherwise referred to as the "gold" coolant.
What year is your truck?
What's the name and the brand of coolant?
Stewart
#65
My truck is 1994 F250 7.3 IDI NA
I saw those specs on the Walmart Supertech (green in color ) and Advance Auto Parts house brand containers (unopened) that I had in my garage. It does appear that these coolants have HOAT additive compounds. I wonder if it would be okay to SCA to it ?
- Thanks
What's the name and the brand of coolant?"
- Thanks
#66
Ford started using this silicated H-OAT formula starting with the 2002 model year trucks, traditionally gold in color, equivalent to the Zerex G-05 coolant.
I wonder if it would be okay to SCA to it?
BTW, because of the year of your truck, per International who made your engine, a traditional ethylene glycol ("green") coolant is the only one you should use, along with a proper SCA package.
A Hybrid-OAT (the Ford "gold") or even a heavy duty Extended Life Coolant (an OAT coolant, usually red in color) is not recommended for your truck.
Stewart
#67
Thanks for the feedback I think that I will pass on using those jugs of Walmart and Advance house brand antifreeze in my Ford IDI with SCA.
I have heard that Advance Autoparts sells "green" Peak antifreez that is not labeled 5yr/150k mile or "extended life" . If that is the case , I will use it to mix with the NAPA Kool FIL-4058 SCA that I already have.
Now to find a place to buy a few test strips (not a case or bottle that will expire before if use them) .
- Thanks
- Thanks
#69
I've just found out that Valkvoline is no longer supplying the Zerex HD EL non silicate antifreesze. In prep for doing a flush and EL fill purchased 4 gal a few months back as that was all the NAPA outlet had in stock. Went to several stores over the past month to get a spare gallon and couldn't find anywhere. Also no longer shown on either of their websites. Question is what other non silicate HD EL antifreezs can I use if I need to top up my rad ??? Can Gooch pls help answer this??
#70
#72
#73
#74
#75
Pre 99-1/2 should NOT use ELC. It attacks the sealant used for the injector cups, and eventually causes a leaking problem there.
Use the green, low-silicate, with the SCA of your choice, DCA-2 or DCA-4.
Ford uses the DCA-4 (Fleetguard), but I personally use DCA-2 (PenCool 3000).
See this for an explanation of the difference:
http://www.fcocrv.org/Documents/PDF/...CA-2_Gooch.pdf
Pop
Pop
