Old 11-19-2014, 05:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Coolant System Guides
Print Wikipost
Gooch's Radiator/Engine Backflush Procedure and Coolant Information
  #151
Old 06-01-2012, 11:04 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Originally Posted by trekbasso
Thanks for keeping up with this Stewart.
I did the water pump, etc., and flushed and hoses at same time. A great way to do the flush with it all apart.
Very glad I changed to the re-routed hose, as I have had to change the belt twice since doing the flush, nice not to break coolant system open.
Yeah, swapping out to the hose that goes around the belt is much nicer, I agree.
Stewart
  #152
Old 06-08-2012, 01:42 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Originally Posted by Stewart_H
Adding Trey's water pump removal vid to the thread. Can never have too many instructional videos!
Thats why I do em! Another view, another angle, and another opinion can never hurt
  #153
Old 06-09-2012, 12:26 PM
hammer65's Avatar
hammer65
hammer65 is offline
Finished changing mine today. The G05 I took out looked as good as new. I wanted to get the ELC in there, so I picked up 6 gal. of Delo full strength. 6 gals from Distributor was cheaper than 4 gals in the Auto Parts houses. Couldn't find Delo.
Cat was $108.00 for 4 gals and they didn't stock it in full strength.
  #154
Old 07-14-2012, 08:21 PM
NewXer's Avatar
NewXer
NewXer is offline
Thanks for these instructions!
Great directions... water pump, hoses, thermostat, belt, and Zerex HD ELC all done.
  #155
Old 07-18-2012, 03:19 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Does anyone know how to get in contact with Mr. Gooch? I would like to do a video how to using his method, but as it is the Gooch method I would like his permission, per common courtesy policy.
  #156
Old 07-18-2012, 04:06 PM
Sigskydiver's Avatar
Sigskydiver
Sigskydiver is offline
Stewart
Re-routed hose? Okay, where do I get one?
  #157
Old 07-18-2012, 04:18 PM
VegasFordSD's Avatar
VegasFordSD
VegasFordSD is offline
NAPA auto parts... I believe it's just an early 99 hose, have no idea why they changed the design.
  #158
Old 07-18-2012, 04:32 PM
Stewart_H's Avatar
Stewart_H
I've sent him a message.
They were used on the rigs with duel alternators, like ambulances.
Ford part number: F81Z-8260-CA
NAPA Auto parts:
Upper hose through the Belt....(not recommended).... 9175 (standard single alt)
Upper around the Belt.....(recommended)................. 9066 (dual alt)
Lower hose.............................................. ........... 9067
Stewart
  #159
Old 07-21-2012, 10:10 AM
sneltyr's Avatar
sneltyr
sneltyr is offline
Chevron Delo ELC
Stewart - You posted a link to Chevron to find the Chevron Delo ELC. I am in Houston and need to get some to perform Gooch's flush.
I'm not sure what page # or post the link was on.
If anyone knows where I can get the Chevron Delo ELC in Houston I would appreciate it.
  #160
Old 07-21-2012, 10:57 AM
trekbasso's Avatar
trekbasso
trekbasso is offline
Hi sneltyr, I bought some in Houston earlier this year. Bought from a distributor, Sun Coast, near the east loop. I am not in town and don't have access to numbers, but I googled Delo ELC in Houston, and started calling.
I had to buy a case of six, about 120 dollars. Just be sure they get the concentrate,the guy brought out the 50/50 first. They are set up for retail, but it is not a store front type of place. A large warehouse with an office.
Good luck.
  #161
Old 07-21-2012, 10:58 AM
Pyancey's Avatar
Pyancey
Pyancey is offline
Go to NAPA and get fleet charge that is not 50/50. Much easier to find.
  #162
Old 08-29-2012, 01:27 PM
wrd0225's Avatar
wrd0225
wrd0225 is offline
I am confused. I would like to know the name of a specific SCA that I can buy at Napa or anywhere to use in my 1988 F250 7.3 IDI and what the specifications are. I have read and read. I still don't remember seeing this information.
Thanks in advance.
Bill
  #163
Old 08-29-2012, 01:37 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
PenCool 3000. It's DCA-2.
Pop
  #164
Old 09-01-2012, 01:49 PM
cruzer17's Avatar
cruzer17
cruzer17 is offline
Originally Posted by PaulDH
Thanks, two hours researching and I finally decided to go the Guzzle coolant bypass filter route:
Welcome to guzzle's Coolant Bypass Filter Mod Web Page
Oh yeah, also located a source of the Delo ELC in Anchorage, Alaska. Sounds like the way to go when I flush and refill the coolant in my 7.3L PS.
Paul,
Where in Anchorage did you find the Delo Elc? I'm in the Valley and I'm having a hell of a time.
  #165
Old 09-01-2012, 04:21 PM
PaulDH's Avatar
PaulDH
PaulDH is offline
Delo ELC
Jeff,
I sent you a PM. Got if from a bulk Chevron business down on the Port in Anchorage. Just past the homeland security guard station about 1-block on the right hand side. I don't recall the business name...
Paul
Quick Reply: Gooch's Radiator/Engine Backflush Procedure and Coolant Information
