77 F250 460 C6 TRANSMISSION lines ???
Old 08-13-2011, 11:36 AM
KrautBurner's Avatar
KrautBurner
KrautBurner is offline
I've got a 1977 F250 Supercab
it's got the stock tranny cooler (built into the radiator) as well as an aftermarket tranny cooler
I had one of the lines blow off a while back, side of the road fix was to bypass the aftermarket tranny cooler and limp back home
I went to re-connect the cooler, and realized: I don't know what dirrection the fluid flows from and back to the tranny
this shouldn't really matter much in a closed loop
but, since I've got the factory cooler and the aftermarket
I'd like to have the fluid go thru the factory one first, then to the aftermarket Air finned cooler before going back to the tranny.
any way to tell which tranny line is the supply/return?
Thanks in advacne
Russ
Old 08-13-2011, 12:42 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
The line that comes out of the forward section of the transmission is the flow to the cooler, the line that goes to the rear of the transmission is the return from the cooler.
Old 08-13-2011, 12:58 PM
KrautBurner
perfect !!!
that's exactly the info I needed.
Thanks
Ezalycasaid
05-27-2016 08:27 PM
Lstanley
11-11-2011 10:10 PM
polar88
04-30-2005 09:43 PM
JBronco
1978 - 1996 Big Bronco
03-17-2005 06:42 PM
mybigredford
08-24-2004 12:33 PM
Quick Reply: 77 F250 460 C6 TRANSMISSION lines ???
