Help fix speedometer
Pull the housing out of the side of the transfer case (or tranny) that the cable screwed to and inspect the plastic gear, it may be stripped. The housing is usually held in with a bolt and a metal clip. If that's ok, then the gear on the output shaft must be missing or has moved, and that's not so easy to fix, but not impossible.
on
The Speedometer cable gear is really easy to change. Just make sure you get one with the same number of teeth, and the same color or it will change the calibration, "speed" of the speedometer.
The speedometer drive gear inside the transmission requires the output shaft to be removed, or the transfere case to be disassembled enough to reach the gear.
Both the cable and drive gears are plastic, and requires you to replace them with the same color, and number of teeth, otherwise it will change the calibration "speed" of the speedometer.
If you can't find it, then that's probably why your speedo doesn't work. It's a large probably 3/8 diameter stiff cable.
Next step?
Did you pull the housing out of the transfer case and look at the plastic gear? If not, do that and see if the gear looks ok. If it does, then the other gear on the output shaft may have a problem. You might be able to stick your head up there with a flashlight and take a peak in the hole to see the other gear on the shaft after you pull the speedo gear housing out.
Do you have factory cruise control? If so you probably have two speedometer cables that join at the speed pickup coil of the cruise. It will be near the brake booster. Make sure it's connected all the way through to the speedo. Follow the cable from the firewall to the speedo and see if it's been disconnected. If it's loose behind the dash try snapping it back on to to the back of the speedo. Feel first to see if the inner drive cable comes all the way through. A previous owner may have pulled the short section above the pickup coil if he thought it was noisy.
on
Very good point. There is also another plastic piece that fits into the speedometer head that can snap off. That can be seen with the instrument cluster removed. The instrument cluster should be removed and the speedo cable removed from it's outer housing, inspected and lubricated anyway for routine maitenance.
vance001
05-14-2020 06:55 PM
moetrucker
11-05-2016 04:02 PM
