Head studs. Coolant drain?
Neal, no need to drain the coolant. Do the studs one at a time and you won't allow the head to lift any to ruin the factory seal. Are you using H-11's or ARP's???
*****, the reason we have a good seal is b/c we have been running these head gaskets for 13-15 years and around 150k-300k miles. all those heat cycles let the gasket seat really really good. thats why you usually don't want to use new gaskets if your just doing studs. of course if the head comes off you have to use a new gasket and take it through some heat cycles to seat it.
I have already don one head, and yes I am doing them one at a time. Full torque and looosen 3 times them back over then all for a 4th torque as per manufacturers instructions.
No William I did not pull the head off in the truck. I believe I would rather pull the motor if that were the fact.
The reason I ask such a stupid question is because I am seeing something that makes me wonder. Some of the head bolts that I pull are damp. Nothing dripping mind you. Just a tad damp. And when I taste it it is sweet just like antifreeze. Hmmm?
I have spoken to several people on the phone about this and I have been told that I was not the only one who noticed this. Theirs was damp too and have been running on the new studs for about a year with no problems.
Things that make you go Hmmmm?
I didn't think you'd remove em neal, but Thought i'd ask anyways. You are really unpredictable you know. =)
I didn't loosen mine after each torque. Was a supposed to? I did the 4 torque stages but waited a minimum 30 minutes in between each. Done 2 trucks like that with no problems thus far, but wondering if I'm doing it correctly. I have another motor to stud (w/o pulling the heads) next month.
I'm wondering if there's some of the stud holes that pass thru the water jackets?
That was my thought too but if it did then the coolant should go into the hole and not allow the new stud to go in there.
I looked real close at them last night and I don't see where the coolant could flow where the studs are.
On some I also noticed when I dropped the stud in there when tightening I would hear that same sucking/squirting sound you hear when I would screw them in by hand. I would wiggle them loose and tight both ways to be sure the stud went in as far as possible when I heard that.
None of the studs are at different heights which indicates to me that all off them are bottomed out and at the same depts with one another. So I should be good. Like I said I am not the only one with this question in my mind but nobody seems to have any issues with it.
Neal
Oh yeah, Ryan. The part about loosening between torques is what was dictated in the instructions that cam in the box. It also said to do them all at 125 ft.lbs. each.
Torque
loosen
torque
loosen
torque
retorque all of them without loosening.
Basically 4 torques with 2 loosening.
I think the last torque I may go to 130 just for *****s and giggles, in the circular pattern of course.
I am doing all of this in the specified circular sequence.
Torque
loosen
torque
loosen
torque
Good to know. I can't remember for sure now if I did the 1st motor that way or not. I know for a fact that I didn't do that with the motor in my current truck. I had to pull the heads on it though. I've got close to 3000 miles on the new gaskets, headstuds, and setup. So far no trouble. Most of those miles are pulling my big horse trailer. Took it easy for the first 1000 miles, since then I've just been driving it. I've hit 30+ psi quite a bit with no headgasket issues yet. And that's with no programming! Just injectors and big oil on stock pcm.
mike L
23
07-13-2006 11:37 AM
