HEI conversion how to - Ford Truck Enthusiasts Forums
Old 05-26-2010, 11:36 AM
cOpE!'s Avatar
cOpE! cOpE! is offline
cOpE! is starting off with a positive reputation.
Hey everybody,
Just got done swapping my 82 bronco, 351w to an HEI set up. I got it on ebay from skipwhite performance. It was one of the easiest upgrades ive ever done on a car or truck. It now runs MUCH smoother and quieter. I used to be able to feel a slight lope while the truck sat at a red light, now I have to look at the tach to make sure its still running! Acceleration is smooth through all 4 gears. If anyone is considering this mod, I reccomend going through skip white, they were very helpful and easy to deal with, plus I got the complete distributor with coil and cap for only $52 shipped! Any how to questions hit me up and Ill be glad to help.
Old 03-24-2014, 07:50 AM
mtfleming11 mtfleming11 is offline
mtfleming11 is starting off with a positive reputation.
Hey guy, looking for some help with this, I'm doing the same thing. I'm taking a 93 351w with 80k miles and putting it into my '81 F100 in place of its 300 I6 with 460k miles. How is it done?
Old 10-22-2014, 09:21 AM
BossFan BossFan is offline
BossFan is starting off with a positive reputation.
I just looked on their site and I think I am going to go this route as well. The plastic parts of my Duraspark ignition have just crumbled in my hands as I removed them.
Old 10-22-2014, 08:06 PM
LARIAT 85's Avatar
LARIAT 85 LARIAT 85 is offline
LARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to beholdLARIAT 85 is a splendid one to behold
Quote:
Well, I am glad you got your truck running smoothly again, but I wouldn't call that an "upgrade." Skip White Performance HEI doesn't do *ANYTHING* better than your stock Motorcraft Duraspark ignition did. At all. I promise you that your truck did not "lope" when it was brand new and had a properly functioning ignition system.
You just performed the classic "Magazine test." That is where a magazine takes a vehicle with old, worn-out stock parts (32 year old Duraspark ignition) and replaces them with the latest, brand-new aftermarket parts (Skip White Performance HEI ignition) and uses before/after tests to "prove" the aftermarket stuff is superior to the stock parts. But was it? Or was it just new?
Old 11-01-2014, 05:22 PM
Motorhead351 Motorhead351 is offline
Motorhead351 is gaining momentum as a positive member of FTE.Motorhead351 is gaining momentum as a positive member of FTE.
Once swapped new duraspark II components for old duraspark II coil/module, then new duraspark components for a tfi coil/ HEI module using same duraspark II distributor.
Anecdotally speaking, cold starts improved dramstically.
Personally would not hesitate to use an HEI distributor designed for the SBF.
Old 11-01-2014, 05:51 PM
LARIAT 85's Avatar
Where did you purchase the Duraspark coil and module?
Old 11-14-2014, 07:56 AM
silar's Avatar
silar silar is offline
silar is starting off with a positive reputation.
I did this conversion also. It was ridiculously simple to do..
The primary reason I did this was because I am somewhat modding my truck, and wanted to minimize the amount of wires to the engine. With an HEI, I was able to remove the separate coil and module...
I got mine from ebay. It was around $50 shipped. I was thinking... If it works, then great... If not, then I'll ship it back or just eat the cost and buy another distributor. It worked flawlessly and I've had zero issues with it. Not sure of the longevity with it though, but so far.. nice.
Who's running an HEI distributor on 302? Mitchapalooza 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 02-24-2016 04:38 PM
Finished hei module swap. Got a few questions JayzDaddy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 06-05-2015 11:29 PM
anyone running HEI greentruck72 1973 - 1979 F-100 & Larger F-Series Trucks 1 03-10-2015 12:40 AM
HEI Question Johnny Be Cool 1973 - 1979 F-100 & Larger F-Series Trucks 8 02-03-2015 08:37 PM
truck instantly gets hot then Lumpy78 1967 - 1972 F-100 & Larger F-Series Trucks 16 10-11-2014 12:04 AM
Tags
289, 351, 351w, 87, bronco, conversion, distributer, distributor, ford, hei, ignition, skip, upgrade, white, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
