You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I used the Meguires plastic polish with a pad and my electric drill....rotating SLOW - if real bad, use wet #1500-2000 sandpaper first. Used this on my '97 Lincoln. Might have to retouch about once a year. Looks crystal !
__________________
BPofMD - Bud - USN-Actively Retired
Maryland Chapter Plankowner
2005 F250 PSD 4X4 LB Crew-cab Arizona Beige / Blue Spring / Gauges / Coolant Filter / SG-II / Peragon Bed Cover/ P/S Filter/ MAG-HYTEC differential cover/
2007 Arctic Fox 30' Fifth Wheel -2012 VW Passat SE TDI (An ALL-DIESEL family) Join the Maryland Chapter click HERE
Never touched them with sandpaper and actually have done all mine with my buffer and a little bit of polishing compound
__________________
Dave
92 F150
Chapter Member
Life's journey is not to arrive at the grave safely in a well preserved body,but rather to skid in sideways totally worn out shouting"Holy Crap, What a Ride" R.I.P.Marty, Jason
I see that Harbor Freight has a H/L Restore Kit on sale for 9 bucks. Gotta use your drill. Can't go wrong with that. You'll need the coupon. Go to: 12 Minute Headlamp Lens Restoration Kit
__________________
Update: I finally got around to working on the heaqdlights today. I have to admit I went the cheap route. I took a piece of 1500 snadpaper and wetsanded them and then polished them here are the before and after pics.
__________________
Rick Kerfoot
89-F250 Project truck
drill a small hole inside, near the bottom on the right light, it will make the condensation go away, and bulbs will last longer. lights look good. want to do mine? I'll let cha.might burn something on the grill while you work for payment.
__________________
Charlie slackmaster #26 "A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
"If more sane people were armed, the crazy people would get off fewer shots."
"Some people are alive because it's illegal to shoot them"
Thanks. Hey Charlie, how about you replace my rocker arms amd i'll do you headlights. I might even do the tail lights too.
I'll help with the rockers, just to help, you don't want to do my lights, I have too many trucks.
__________________
