7.3 idi starter is toast - Ford Truck Enthusiasts Forums
Old 05-25-2010, 11:08 PM
dwalphinVT's Avatar
dwalphinVT dwalphinVT is offline
dwalphinVT is starting off with a positive reputation.
I have a 1989 7.3 idi and the starter has gone out on it. Sometimes its starts right up and sometimes it just clicks. Is there an aftermarket starter that I can get that will turn over faster than the stock one? Starts great in summer but this past winter it had to turn and turn to get it started and would like something with some more power to it. Thanks for any info in advance.
Old 05-25-2010, 11:17 PM
oreocreaming's Avatar
oreocreaming oreocreaming is offline
oreocreaming is gaining momentum as a positive member of FTE.
dont think its your starter. check your starter solenoid
Old 05-25-2010, 11:35 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
and cables/terminals for corrosion.
Old 05-26-2010, 10:55 AM
gumboluvr's Avatar
gumboluvr gumboluvr is offline
gumboluvr is starting off with a positive reputation.
I had one that would drag. It gave me fits for months because folks here kept saying my starting problem was air intrusion. I think the gear reduction Mitsubishi is the replacement for these trucks. Word to the wise, bring your old started to the store. They will give you the wrong one about half the time.
Old 05-26-2010, 11:15 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
As stated, check cables and grounds. Just because cable look ok does not mean they are, do they get warm/hot at the terminals while cranking, many times the issues are inside the connectors.
There are also TWO solenoids, one on the inside of the fender, and one on the starter, check them both ...
However, if the starter is getting weak, replace, Diesels need to spin pretty fast to start easy.
Also ensure your Glow System and Fuel system are in tip top shape.
-Enjoy
fh : )_~
Old 05-26-2010, 04:25 PM
fast70's Avatar
fast70 fast70 is offline
fast70 is starting off with a positive reputation.
mine was doing that and then took a crap on me at a customers house we had to send some one to go get the sylinoid that goes on the starter from advanced autoparts and now it spines alot faster then it ever did
Old 05-26-2010, 10:37 PM
Quote:
sig:
94 7.3L Factory Turbo
i notice you have a 94.
when asking for parts,no matter what it is.always say you have a 93,and so many of your problems will be gone forever.
starter tjc transport 1999 - 2003 7.3L Power Stroke Diesel 7 10-26-2016 04:22 PM
start no start issue kavik9 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 03-08-2016 11:34 AM
7.3 idi jerryrigged ignition, won't start without Starter Fluid Lharrell17 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 10-21-2014 01:16 PM
Need starter for 7.3l idi firegod75 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 07-14-2014 12:52 PM
Problem starting 97 250. starter spins but no grab Madmaxz 1994.5 - 1997 7.3L Power Stroke Diesel 12 02-10-2011 09:37 PM
Tags
1992, 73, check, click, diesel, ford, gear, high, idi, info, mitsubishi, motor, reduction, relay, speed, starter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
