1997 Interior and running board lights stay on - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-09-2002, 06:40 PM
58budman 58budman is offline
58budman is starting off with a positive reputation.
Post 1997 Interior and running board lights stay on
I was wondering if any of you have experienced this From time to time my Expeditions interior lights stay on as well as the running board lights as if a door is open but is not. Any suggestions??
Old 02-09-2002, 06:48 PM
BigMick_97_Expy BigMick_97_Expy is offline
BigMick_97_Expy is starting off with a positive reputation.
Mine are doing the same thing. Some times that stay on for a long time and some times not....
Big Mick
1997 Expedition XLT
K&N Air Intake
Hellwig Anti sway bar
Flow master
Plus extra mods.....
http://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=1440&.jpg
Old 02-09-2002, 08:53 PM
pete68 pete68 is offline
pete68 is starting off with a positive reputation.
The interior lights in our '97 Expy did the same thing when we first picked it up. You'll notice the "door ajar" switches on the Expy aren't the usual "push button" type you used to see on cars (I noticed this the first time when I was working on something with the door open and tried to find the button to cut off the light).
Anyway, one of these sensors isn't sensing the door is closed. Try to figure out which one by noticing which door is open before the problem occurs (this may take some time to determine if it isn't the driver's side front door- since this door is presumably opened each time you take the truck somewhere). The fault in ours was the rear driver's side door. Our Ford dealer fixed the problem (I'm trying to remember how... I think he pried up the sensor cover- he DID say that spraying WD-40 down into the sensor area usually does the trick).
Good luck! BTW, the reason the lights sometimes stay on for a long time is because there is an automatic light cutoff even if the door is left ajar. Also, to really check if this is the cause, pay attention to the dash panel when the lights stay on... if the sensor is the problem, you will see the "Door Ajar" light shining.
Old 02-09-2002, 09:05 PM
Great thanks for the info I will try to spray the sensors and see if that helps it It only seems to bother in the real cold weather. Thanks again.
Old 02-11-2002, 11:10 AM
Boxter Boxter is offline
Boxter is starting off with a positive reputation.
I had a friend of mine that had the same issue. However, it was always after his wife drove the truck. After thinking about it for a minute or 2 I thought about the interior switch for the lights (the turn up or down the interior lights on the dash). In the up position, all the lights (including the running board lights) would come on.
When she would get into the truck, she was somehow hitting the switch and turning the lights on.
Prob not the case here, but worth a look (cheap repair).
Boxter
Old 02-12-2002, 02:14 PM
adelyser adelyser is offline
adelyser is starting off with a positive reputation.
Old 02-12-2002, 08:19 PM
TJM97_expy TJM97_expy is offline
TJM97_expy is starting off with a positive reputation.
Had the same problem with my 97 E.B. the dealer fixed it by replacing the "pin switch"he stated it was a common problem. good luck
Tom
Interior / running board Light problem Dtgl1 Excursion - King of SUVs 12 12-09-2015 02:41 PM
Just wondering Paultv Excursion - King of SUVs 7 04-22-2012 02:43 PM
Running board lights stay on shanethomas67 1997-2006 Expedition & Navigator 2 05-31-2009 09:37 AM
exterior/interior light timer pdqtimetrialer 1997-2006 Expedition & Navigator 2 08-04-2005 10:56 AM
Interior Lights and Running board lights stay on ratast440 1997-2006 Expedition & Navigator 9 11-22-2004 02:42 AM
Tags
1997, 97, board, dome, expedition, expedtion, ford, inside, interior, light, lights, running, side, stay, times, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
