ac problems blowing hot air but is charged
charged my ac three weeks ago worked great yesterday it started blowing super hot air opened the hood and clutch was staying on however i thought maybe low pressure charged and the indicator went straight too warning >> released all the pressure tried again nope no cold air and all keeps building pressure any ideas where to start looking here
Were you checking pressure on the low side or the high side?
If your low pressure is going high, it's most likely because of lack of airflow through the condenser.
If the high side is going too high, it is probably due to a restriction in the system, usually at the fixed orifice. Recover the system and remove the valve and inspect. Metal debris indicates a failed compressor. Grit or sand-like material is usually due to dessicant failure in the accumulator.
Jay
Jay
76250_4x4
16
06-13-2012 03:00 PM
mechman787
1997 - 2003 F150
07-19-2008 06:04 PM
