05 F250 6.0- No Power Towing and Losing Coolant!!! - Ford Truck Enthusiasts Forums
Old 05-25-2010, 03:20 PM
campr campr is offline
campr is starting off with a positive reputation.
Hi there,
This is my first post and my first diesel. Just did a regular maintenance befor our first camping trip with the Ford (oil, fuel filters). I was quite embarrassed when I was getting passed by 89 Dodge half tons going up hills when mine matted would only do about 60-70 km! All gauges read fine, but the turbo had a real loud scream to it and coolant was leaking out of the resevoir cap! It ran fine on the flats, but as soon as it came to the hills..... FYI my trailer only weighs 5000lbs + quad and dirtbikes, maybe 7000lbs at the most.
Old 05-25-2010, 03:59 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
Check for EGR cooler leaking / bad and with that, oil cooler plugged or both.
How many miles you got on it?
Old 05-25-2010, 04:07 PM
OK I've only got 105,000 KM on it.
Old 05-25-2010, 06:38 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
You can park your truck on a downslope and pull your EGR valve. If the EGR cooler is leaking, it will be wet with coolant under the valve.
You could also have head gasket issues, NAPA sells kits for checking for combustion gasses at your degas bottle.
Old 05-25-2010, 07:04 PM
Kep4's Avatar
Kep4 Kep4 is offline
Jäger
Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.Kep4 has a spectacular reputation.
Quote:
Originally Posted by campr View Post
All gauges read fine, but the turbo had a real loud scream to it...
Do you recall the turbo boost psi reading on the boost gauge at the time?
Are you sure it was the turbo 'screaming' and not the engine fan?
Was it running hot? If so, is it now running hotter than previous?
Old 05-25-2010, 10:18 PM
It wasn't running hot at all. The turbo was reading at about 25-30psi. I just took it to a Ford diesel mechanic close to Calgary here and he was positive its the head gasket. Not what I wanted to hear.
Old 05-25-2010, 10:21 PM
Depending on your in-service date, it is a warranty issue.
Old 05-25-2010, 10:25 PM
Warranty is all done as of Febuary. Of course!
Old 05-26-2010, 08:19 AM
lawnboy1965's Avatar
lawnboy1965 lawnboy1965 is offline
lawnboy1965 is starting off with a positive reputation.
Welcome to the club and not a good club at that. Mine did the same thing with only 5000lbs loaded on the trailer and is going in next week for HG's, but it is still under the esp warrenty I purchased when I bought it. May as well studd it while your in there, you can get them for 395 but im sure they will charge shipping to canada, thats just an assumption as I saw you have 105,000KM's on your truck.
Old 05-26-2010, 09:49 AM
hndacr hndacr is offline
hndacr is starting off with a positive reputation.
I am not saying it isn't HG's, but it seems to me that many of these trucks are mis-daignosed with HG failure when it is really the oil/egr cooler failing. The loud noise you heard was most likely the fan coming on because your oil temp was climbing. My truck did the same thing last year and I thought I lost boost at first also. When that fan comes on, it sounds like a 747 spooling up under your hood and in my case all power and fuel mileage went to crap. I ended having a 50*+ spread between oil and coolant temp. If this is on your dime, I would make sure the tech tests the system properly for a HG failure. Lets hope he was initially wrong!
Old 05-26-2010, 10:21 AM
Thanks guys. I appreciate the sympathy! I will make sure he checks it thoroughly before I commit to anything. Has anyone had any luck getting Ford to pay some of it after warranty's over?
Old 05-26-2010, 11:22 AM
Kep4's Avatar
Jäger
Welcome to the 6.0 Blown HG Club!
As lawnboy suggested, see if you can get the Tech to replace the Ford/Navistar TTY head bolts with ARP studs. That will keep those heads firmly seated.
Great advice above regarding the oil cooler and EGR cooler, both of which should probably be replaced while it's in for surgery. You should also consider adding a coolant filter which will prevent the oil cooler from getting clogged which causes the EGR cooler to fail.
Has the STC fitting been replaced with the updated version? That's also a strongly suggested upgrade during surgery.
Old 05-26-2010, 11:42 AM
Quick question, are trucks from Canada under the 100,000 KM or 100,000 mile warranty? If its mile you only have a little over 65,000 miles and should be under warranty yet depending on the purchase date, just a thought.
Old 05-27-2010, 09:56 AM
I think because it is an 05, his inservice date puts him out of warranty.
Old 05-27-2010, 11:06 AM
jlong05 jlong05 is offline
jlong05 is starting off with a positive reputation.
If he hasn't had any other 'warranty' work done, Ford also offers a one time out of warranty repair for original owners. I know its doubtful it hasn't had anything fixed, but it is worth noting.
6.0 problems. high egts. high boost psi kd0nfq 1999 to 2016 Super Duty 2 08-21-2014 06:43 PM
Diesel in Recovery reservoir? towme 6.0L Power Stroke Diesel 51 08-26-2013 03:41 PM
I Think I Jinxed Myself skidooman1990 6.0L Power Stroke Diesel 57 02-13-2013 04:16 PM
injecters? water in fuel? shawntxt 6.0L Power Stroke Diesel 22 09-11-2008 07:55 PM
F-250 V10 No Power? Daren12 1999 to 2016 Super Duty 4 03-29-2003 10:48 PM
Tags
2004, 2005, 60, coolant, cooler, diesel, egr, excursion, f250, f350, ford, loosing, losing, manual, repair
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
