It looks like i'll need a belt tensioner soon, i have read somewhere here that you can swap out the a tensioner from a superduty. is that right? if so what do i need to do the make the swap and what belt would i need to get to match up? Thankful fof any and all ifo y'all can give me.
Actually there are:
OEM tensioner (short arm)
Upgraded Tensioner (longer arm)
SD tensioner (with two pulleys and you have to mod the bracket)
Ill be here with more
The dual pulley tensioner is a real nice upgrade. I put one on mine and its the bees knees. You will need a longer belt. Might as well replace the other wheels while your there. I'll try to dig up the part number of the Goodyear belt I used and post up.
