1986 E250 rough idle, stalls 351 carb 28k
Sounds to me like it could be a sticking EGR valve. With the engine warmed up and running
at around 2,000 RPM, pull the vacuum line off the valve and watch the diaphragm, it should
fully close.
The EGR recycles exhaust gasses back into the combustion chamber under certain conditions
to lean out the misture - generally while fully warmed up at highway speeds. It is not supposed
to operate while the engine is cold and/or idling but they sometimes get carboned up inside and
stick open.
The valve lookspretty much like this:
It fits on a plate between the intake manifold and carburetor and the diaphragm should be behind the carb:
fully close.
stick open.
I have the EXACT same problem as you, I'd post symptoms but they are verbatim to yours. The difference is mine is a EFI. I have replaced the EGR valve, the IAC valve, the fuel filter, spark plugs, the throttle positioning sensor, cleaned my intake manifold, seafoamed my intake, replaced the 02 sensor as well. None of the those did jack. Its been a month and a half and several hundred dollars. I leave for college in 5 weeks and I have a truck that doesn't stay running, would love to hear what y'alls opinions are.
Thanks
Thanks
I had a similar problem awhile back...
My truck would start fine and idle alright, but as soon as I dropped it in gear, it would not hold an idle. I had to keep my foot in it to keep it running. Same with driving it around, it shook and ran rough.
Turns out it was due to worn out spark plug wires. I guess they leaked voltage or were just not letting enough power to the plugs, because as soon as I installed new wires and fresh spark plugs, it was as though I had a whole different truck. Fast idle was better, it would maintain a nice low idle in park -and- in gear, and it ran as smooth as silk in gear while driving.
great info in this thread, awesome resource, thanks guys.
just bought a nice old 83 bronco with this same dying when you press the brakes issue. nice to know there is a place to pick up some tips to help me fix my new ride. I was guessing vacuum leak of some sort but I'll know more tomorrow when I do the tune up and check it all over... al
olddudeford
12-06-2016 06:59 PM
GreenMM
43
04-21-2016 09:15 AM
FOURPAWS
11-06-2015 01:22 PM
Reed
27
04-29-2012 08:56 AM
