Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 05-24-2010, 01:22 AM
st381 st381 is offline
Garage is empty, add now
st381 is starting off with a positive reputation.
Climate Controlled Seat
I know this is a rehash of some older threads but I thought it might help some other noobs like me.
I have an 07 EL Expy Limited which I purchased used with 35799 miles on 4/29/10. The AC seat works but doesn't seem to be very cool. Wife says passenger seat gets her too cool. I see a TSB for the issue: 07-15-5 08/06/2007 A/C, Interior - Poor Climate Control Seat Cooling but I am unable to find the TSB or see if I can trouble shoot this myself.
I also had the mysterious "clicking" noise on the driver's seat when power was off which I was able to stop by slightly adjusting the power adjust control. Noise hasn't returned but nags my sense of doom.
Does anyone have the info on the TSB regarding poor cooling on climate controlled seats? I bought the FORD extended warranty on the vehicle and should be covered if a trip to the dealership is necessary.
Finally, is there a website that I can enter my VIN into and check to see if all recall work was done to my ride. I know I can probably go to the dealership but why if I don't have too.
Thanks in Advance for your help and patience,
st381
  #2 (permalink)
Old 05-24-2010, 11:18 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
TSB 07-22-4
11/12/07
POOR SEAT COOLING PERFORMANCE - BUILT BEFORE 7/16/2007
FORD:
2007-2008 Expedition
LINCOLN:
2007-2008 Navigator
This article supersedes TSB 07-15-5 to update the Service Procedure.
ISSUE
Some 2007-2008 Expedition and Navigator vehicles built before 7/16/2007 and equipped with climate control seats, may exhibit poor cooling performance in the seat.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Verify there are no diagnostic trouble codes (DTCs) and that the thermal emitting device and fan assemblies are working properly. Then use IDS to select the Maximum Output Mode. This will increase fan speed to provide quicker cooling.
1. Using IDS (equipped with release B51.5 or higher) normally ID the vehicle.
2. Select "Toolbox" at the top of the screen.
3. Select "Module Programming" from the menu.
4. Select "Programmable Parameters".
5. Select "Climate Control Seats".
6. Select "High Cool Blower Voltage" to change setting.
7. Select "Maximum Output Mode".
8. After the preference has been successfully changed, verify that the seat fan assemblies are operating according to the new setting.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
072204A 2007-2008 0.3 Hr.
Expedition/Navigator
Vehicles Built Before
7/16/2007: Check For
DTCs, Then Change The
to Maximum Output (Do
Not Use With 12651D,
12651D4)
DEALER CODING
CONDITION
BASIC PART NO. CODE
14C724 42
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 05-26-2010, 07:47 AM
rjd75 rjd75 is offline
rjd75 is new and has a neutral reputation at this point.
FWIW, I had this tsb performed on my 2007 and it definitely made my seats louder, as in you could really hear the fan, but did not really notice any difference in cooling.. Waiting to see if my 2010 will be any better..
  #4 (permalink)
Old 05-27-2010, 09:52 PM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
my seats are loud as hell also...when they do work. They don't ever get cold though. Temp is set 67-70F and on auto mode. Seats never seem to do the job as described
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #5 (permalink)
Old 05-28-2010, 10:28 AM
CarbonClear CarbonClear is offline
CarbonClear is starting off with a positive reputation.
Quote:
How true!
Mine is set at 60-63F and using the downward vents to see if it will push colder air thru the fans. Its not very well designed. Don't understand why they couldn't just run an A/C return right into the seats as other car manufacturers do
__________________
2012 Toyota Tundra Double Cab 4x4
2007 Ford Expedtion EB
2006 Porsche Cayenne S
2004 Honda Crv
2003 Ford F350 XLT, 7.3 Diesel 4x4 (Sold)
2001 Porsche Carrera Cab
  #6 (permalink)
Old 05-28-2010, 10:35 AM
berry1234's Avatar
Quote:
Originally Posted by CarbonClear View Post
How true!
I think this would have been better. Put a flexible hose mounted to the underside of the seat. Then put a control that would throttle the door allowing you to have the same flow as the main a/c system. Much cheaper and a lot less electronics.
__________________
  #7 (permalink)
Old 05-28-2010, 12:24 PM
Quote:
That would work.....But I think that this would be to puzzling for the Ford engineer....
__________________
2004 Honda Crv
  #8 (permalink)
Old 05-28-2010, 09:52 PM
Tylus's Avatar
Nuke Mechanic
2006 Ford F-250
too true
I should have bought regular seats and ran that duct myself. then used an icepick to make a few holes in the leather. cheap and most likely way more effective
__________________
  #9 (permalink)
Old 05-29-2010, 09:07 PM
too true
Maybe we need to post a video of this and send it out to Ford
__________________
2004 Honda Crv
Tags
2003, 2007, 2008, climat, climate, control, controlled, cooling, expedition, ford, forum, lincoln, navigator, problems, seat, seats, tsb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
