Custom Truck
Custom Truck
Hey guys i have a 1984 F250(kinda a F350 now). I put a 10" flat bed and a ford 10.25 dually axle with 4.10s on it. I also put a 1991 ford idi 7.3l with a banks turbo kit(c-6 auto still) . But my problem is that i cant really go over 55-60 mph cause the motor starts to run really hot like 210-230 and it revs like crazy
Anyway i was wondering about have a shop install a 5 speed or 6 speed trany in my mult year truck.
-Austin
altamont springs FL
-Austin
altamont springs FL
on
My bet is a bad clutch on the fan.
Is it a 2wd or 4wd.
I don't do automatics in trucks ... PERIOD! I dislike them mucho.
Diesel 4wd ZF5's are not cheap and hard to find, 2wd's are dime a dozen. At least around here.
IMO that's high for a 2wd, low for a 4wd.
However, for the headache, it could be well worth it, especially if they have all the factory components like drive lines, pedal assemblies, master/slave cylinders, cross members, etc... If they have to make up drive lines I would be wary, ensure they have the proper equipment to do them.
-Enjoy
fh : )_~
Is it a 2wd or 4wd.
-Enjoy
fh : )_~
Alright well im going to go with the swap i mean ive called everywhere and everyone wants like 2500-3000 dollars so 1500 bucks aint to bad!!!!. Especially coming from a trans shop!! .
i really think that im reving the **** out of the motor and causing it to overheat. when i had 3.55 ratio in it the thing really never went over 170 unless i was screaming aroung 80-90mph!!!!(thats scary in a old truck BTW) P.s ill have some pics up in like two days.
on
A Diesel can run on the governor all day and all night and never gain a degree or miss a beat, thats what they are made to do.
If it's over heating, you have a problem ... PERIOD!
230 degrees is really not that hot, the thermostat is 195 degrees, Diesels like heat to a point, thats what makes them run.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
thanks festus i never tryed to run it at gov fir 5 mins or anything like that. well i did rev it up that high once and the heater core hose came flying off the block lol (untighted clamp oops) anyway How would i check the fan the right way and how and i hook up one of those techs you can buy from the parts store like autozone
on
Hose clamps are made to be tightened to hold and prevent water leaks ...
(sorry just couldn't help myself)
I think this thread explains the Fan Clutch testing procedure: Clutch Fan Hub Test
If not let me know, I have another I can send you via email.
-Enjoy
fh : )_~
-Enjoy
fh : )_~
