Tachometer for a v10 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-23-2010, 09:29 PM
pinger's Avatar
pinger pinger is offline
pinger is starting off with a positive reputation.
I did a search and didn't find what I was looking for..Does anyone know of a reasonabley priced tachometer for a v10 I have a v10 2003 e450 chassis in a Motorhome and would like to find a tachometer for it..only to use it in the mountains..Thanks
Old 05-24-2010, 10:08 AM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Years ago there was a discussion about the E-series V10. I THINK there was a tachometer output from the PCM, but finding it is a chore. I think there's one of those "blunt cut" wires under the dash for it.
Finding a tach that's capable of 10 cylinders, that's even more fun
Old 05-24-2010, 11:18 AM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
Don't know if this helps. But it looks like Autometer has built an adapter for their tachs and the V-10. You might call or email them.
Auto Meter
Old 05-24-2010, 11:41 AM
Krewat's Avatar
More here on FTE, given my google search of "e450 cto tach" (where cto stands for clean tach output, learned from the autometer page linked to by David).
http://www.ford-trucks.com/forums/11...10-engine.html
Looks like you should be able to find a white/pink wire labeled "CTO" under your hood
Also this thread:
http://www.ford-trucks.com/forums/27...achometer.html
Old 05-24-2010, 03:57 PM
pinger's Avatar
Yes I found the cto wire stubbed out under the hood..I called autometer about their tachometers and they said I needed one with 5 pulses and they want an arm and leg for one of their's..I guess that I will do without..
Old 05-24-2010, 05:21 PM
Krewat's Avatar
Old 05-24-2010, 08:34 PM
pinger's Avatar
I found one on ebay for $39 and ask the seller if it would work on a v-10 and he they said it would if I could fine the tach wire which I have found..It's a Sunpro cp 7908 from Summit racing...What do you all think about it? I don't want to buy it and it not work and have to send it back..Has anyone tryed this tach? Thanks
Old 05-25-2010, 08:56 AM
Krewat's Avatar
Owner's manual for that model only shows 4-6-8. Ask him to take a picture of the back of the tach
http://www.sunpro.com/publish/2007/0...lish_16475.pdf
Old 05-25-2010, 08:59 AM
Krewat's Avatar
The only Sunpro tachs I see that work with 10 cylinders are the "retro" versions.
SST802R and FZ88R
Old 05-25-2010, 09:03 AM
Krewat's Avatar
Weird though, Amazon says the CP7915 will work with 10 cylinder engines, but the Sunpro website doesn't say it at all.
I'd still say "look at the back and see if it has a setting for 10".
Old 05-25-2010, 09:17 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
You could get a ScanGauge or the Edge monitor, both will show RPM and will add other functionality as well (mpg, temps, etc).
V10 tachometer rclarke 1968-2013 Full Size Vans 5 05-25-2014 11:49 PM
V10 tachometer fyrfyter Modular V10 (6.8l) 7 08-26-2004 10:06 AM
Tachometer in 2003 F150 XL Henry Ford III 1997 - 2003 F150 5 11-30-2003 11:11 PM
tachs 1978fordf250351m Aftermarket Products 11 09-04-2003 08:47 AM
Tachometer on V-10 engine Hopcraft Modular V10 (6.8l) 8 07-17-2003 09:42 AM
Tags
02, 1999, 68, 97, clean, duty, e450, ford, header, super, tach, tachometer, tachometers, v10, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
