Electric Brake - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Electric Brake
Old 02-14-2002, 02:44 AM
Blue Jeff's Avatar
Blue Jeff Blue Jeff is offline
Blue Jeff is starting off with a positive reputation.
Electric Brake
I Have the 99' E.B. 5.4 with the towing pack. I bought it used and went to hook up the electric brake with the supplied wiring kit and low and behold, the wires and harness had been cut.
Is there a way to determine the wiring? I really would like to hook up the brake with the original system. Thanks for your help. Jeff
Old 02-14-2002, 11:39 AM
pls60 pls60 is offline
pls60 is starting off with a positive reputation.
Electric Brake
Old 11-28-2012, 08:15 PM
drlee drlee is offline
drlee is starting off with a positive reputation.
light problems HELP
2001 f 350 light problems Ok changed the multi function switch ,tested the light switch changed relays and fuses same problem. Disconnected every ad on . High beam light on dash always on, put on low beam looks like high beam ,put on hi beam looks like very lo beam , fog lights will work all the time (shouldn't with high beam ) my lighting problem might be just a coincides with hooking up a plow . Oh by the way when the plow is hooked up it is the same, lights go out on the truck but same high low problem on the plow.
<!-- / message -->
<!-- controls -->
Old 11-29-2012, 11:31 AM
2trux 2trux is offline
2trux is starting off with a positive reputation.
I assume it was a mistake that you append this question to an ancient thread about trailer brakes. You will get more responses starting a new thread and putting it in the truck section of the board
beefing up the rear shocks f100 jeff8362000 1961 - 1966 F-100 & Larger F-Series Trucks 14 11-19-2009 01:44 AM
Trailer wire???--1996 E150 harness Jeff99GT 1968-2013 Full Size Vans 0 04-19-2008 09:49 PM
Spark Plug Wires burning on Headers Jeff Wahl 1987 - 1996 F150 & Larger F-Series Trucks 12 09-25-2007 04:03 PM
05 Expedition trailer brake wiring dogzpaws Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 9 09-01-2007 12:02 AM
Installing Tweeters jeff303 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 05-12-2004 06:25 PM
Tags
brake, elect, everett, hookup, wa
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
