2000 Expedition Front End Alignment
My freind has a 2000 Expedition. His front tires started getting loud prematurely, so he recently took it to a local tire chain shop to have the alignment checked (they've been rotated). The Manager there charged him $60 to adjust the toe in/out. The Manager advised him that they could not adjust the camber/caster, because the front springs had sagged (140k miles on it), and there is no camber/caster adjustment on these, therfore new springs would have to be installed before the proper alignment could be done. I've never heard of this before, in fact, my daughter's 99 F150 just had an alignment 3 weeks ago, and her truck has 179k miles, and it's been abused and neglected. Is this guy jerking my buddy around???
Here's Fords apecifications on ride height and alignment if his truck is sagging beyond the specifications the alignment shop may be right. The measurements must be done on a flat and level surface.
General Specifications Item mm In
Rear Curb Ride Height Specifications: 4x2
Without Air Suspension 168-192 6.6-7.5
With Air Suspension 135-145 5.3-5.7
Rear Curb Ride Height Specifications: 4x4
Without Air Suspension 218-242 8.6-9.5
With Air Suspension 168-178 6.6-7.0
Vehicle Lean Specifications
Maximum allowable variance: Front 16 5/8
Maximum allowable variance: Rear 19 3/4
General Specifications Item LH RH Total/Split
Base Suspension Alignment Specifications: 4x2
Caster 6.1° ± 1.0° 6.6° ± 1.0° -0.5° split ± 0.7°
Camber -0.3° ± 0.7° -0.3° ± 0.7° 0.0° split ± 0.7°
Toe 0.03° 0.03° 0.06° Toe-in ± 0.25°
Base Suspension Alignment Specifications: 4x4
Caster 5.1° ± 1.0° 5.6° ± 1.0° -0.5° split ± 0.7°
Camber -0.2° ± 0.7° -0.2° ± 0.7° 0.0° split ± 0.7°
Toe 0.15° 0.15° 0.30° Toe-in ± 0.25°
Air Suspension Alignment Specifications: 4x2
Air Suspension Alignment Specifications: 4x4
(Trim Position) a
Caster 5.0° ± 1.0° 5.5° ± 1.0° -0.5° split ± 0.7°
Camber -0.4° ± 0.4° -0.4° ± 0.7° 0.0° split ± 0.7°
Toe 0.10° 0.10° 0.20° Toe-in ± 0.25°
(Trim Position) a
Are these numbers l.h. then r.h. ? Also do these numbers cover more than one year? I have a 1997 4x4 with air ride, and I want to make sure these numbers are correct.
(Trim Position) a
(Trim Position) a
limerence
09-08-2016 12:34 PM
Z3T3C
19
08-13-2014 03:48 PM
Bertelrud
06-19-2012 01:47 AM
