Hummer H2 wheels on your F250 - How to and lots of pic's
I have 1978 F250 Crew Cab 4x4 I’ve been working on and as of now I’m running stock 16” steel wheels and was looking for something cheap and attractive to replace them. I really wanted some 8 lug slotted mags but haven’t found any yet for the right price.
So I found a deal on an alternative combo for now. I just picked up a set of 5 H2 wheels and tires for $250.00. I have done some research and decided to take on the task of making them work on my truck.
So I finally had a few minutes to play around with the wheels this weekend and this is my findings. - The H2 wheels will not fit over the rear Dana 60 hub stock, But if you machine the center hub
area they will work.
- So I went to Lowe's picked up a $20.00 Bosch dual fluted flush cut router bit.
- Mounted it in the my router with speed set to the lowest setting
- Flipped the outboard wheel face down, rear side up.
- Measured the depth so that the guide bearing on the bit rides on the outer hub lip.
Just over 1/2"
- Mixed up a bottle of soapy water and sprayed the hub center down for lubrication.
- Held the router firm flat up against the backside of the wheel/lug nut mounts area
and started out slowly. I worked my way around the hub counter clockwise
making several light passes soaping the wheel each time around until the bearing
contacted the outer hub lip.
- Removed the router, wiped down the hub and BINGO - A perfectly machined inner hub surface.
- I cleaned the wheel and vacuumed up all the shavings, tried the fit on the rear
axle and it fit perfectly.
- The clearance at least on the rear looks good. With the H2 backspacing it sits
maybe a 1/4" - 1/2" more narrow than the stock steel wheels width. But the leaf
spring clearance is good.
- As of now I have not tried the fronts because I ran out of time but will get some
time in the next few days.
- Only question now is about the lug nuts. I believe the stock studs are 1/2" -20 on
the F250? The lug holes on the H2 rims M14-1.5 with a 60 degree seat. I
believe that if I use a 60 degree 1/2 - 20 bulged seat lug nut it should work.
- I know some trucks run 1/2" and some run 9/16". I’ve heard of people using both
sizes with stock lugs on there H2 wheels but just wanted to get some more info.
H2 wheel specs
17x8 Wheel
A back spacing of about 5 5/8 inches
8 X 6.5 Bolt pattern
Ready to start
[/LEFT]
Inner hub before - front side.
Inner hub before - back side.
Router Bit
After
Lug Nuts
Stock -
Bulged
Stock lug on the H2 wheel
Just over 1/2"
H2 wheel specs
17x8 Wheel
Ready to start
[/LEFT]
Router Bit
After
Lug Nuts
Stock -
Bulged
Ok here are a few more pic's on the router depth and bearing surface. Also a few of the bulged lug nuts compared to the stocks. Still raining so haven't fit the front wheels on to see if they clear.
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0462aaa.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0462aaa.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0517.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0517.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0519.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0519.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0523.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0523.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0524.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0524.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0516.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0516.jpg" border="0" alt="Photobucket"></a>
The Lugs
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0526.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0526.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0527.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0527.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0528.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0528.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0530.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0530.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0529.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0529.jpg" border="0" alt="Photobucket"></a>
The Lugs
Found a few minutes to try the front wheels and they fit great as well. You don't have to machine the fronts because they do fit of the Dana 44 front hubs as is. But if your going to rotate tires why not do them all. No clearance issues on the steering arms or the calipers. I got all 5 wheels machined and cleaned up today, now just waiting for my new bulged lug nuts to come in and I'll mount them a post some pic's.
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0542.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0542.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0547.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0547.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0548.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0548.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0552.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0552.jpg" border="0" alt="Photobucket"></a>
<a href="http://s285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/?action=view¤t=IMG_0551.jpg" target="_blank"><img src="http://i285.photobucket.com/albums/ll80/drich120376/1973-1979%20Ford%20trucks/IMG_0551.jpg" border="0" alt="Photobucket"></a>
I have 4 stock hummer center caps that I think I might use. If I cut them with a close clearance to the hub I think they'll look good. I've seen people use ford, chevy and dodge centers on the h2 wheels that have been modified a bit but since I have the H2 covers I'll start there see how it looks.
I like it without the covers also but figured I'd see what it looks like with the stock caps cut out and make my final decision. I like the look of the silver wheels but I personally like black wheels. Maybe once I move forward from the mechanical work to the body I'll powder coat them. I'm thinking satin black, or orange paint with black wheels, trim, bumpers etc. I think the wheels look really good on the truck not only the size but also the design. Really for the $250 I spent for the wheels and tires, $20 router bit, and the hour and a half of labor It was well worth it. Not to mention it was very simple to do at home with simple tools.
I looked online for awhile trying to find complete info and pic's for making these wheels work on the my 78'. Mostly info and pic's for Chevy, Dodge, etc but nothing for 73-79 Fords. I hope this info and these pic's help anyone thinking of this swap. I definitely recommend this swap for the budget minded dentside builders.
Anyone need or want anymore pic's let me know I'd be happy to post.
Should have some time this weekend to get the wheels mounted on the truck, we'll see. Pictures to come.
