How bad is this Rust?
I took some pic of the rust from my 65 F100 Custom Cab. Its been sitting since 76'
Tell me what you all think since I don't know squat about rust.
Below is a picture of the passenger side floor pan and door Sil
Below is a picture of the driver side floor pan and door sil
Your truck is a lot better off than a lot I have seen. I have seen some that you could have exited the truck through the floor boards. You can get replacement floor pans and lower door pillars. Just about any panel that is prone to rust on these trucks can be bought new. I certainly would not get rid of the truck for that small amount of rust.
Your rust problem don't seem to be that bad. Take a look at this thread and you will see some bad rust that was dealt with.
https://www.ford-trucks.com/forums/9...storation.html
I was very fortunate with my 65. It was a nearly rust free truck. The only rust issues was the bottom cab cross member on the ends, the front cab mounts, and the bottom of the core support. All was easily dealt with.
May want to check areas mentioned by ddavidv, it could become a major project. Having said that, I tend to favor rescuing these vintage treasures if at all possible. Intend trying to install floor pans in 64 vintage passenger car that was/is one step removed from the bone yard. Anyhow searched few sites and bookmarked magazine articles and FTE threads where member's posted pic's of their projects you may find helpful. Figure with MIG, and basic welding skills might as well give it a try, or at least make it a learning experience.
How To Replace Floorpans
Repairing A Ford Ranchero Floorpan - Custom Classic Trucks Magazine
FTE member threads: These are just a couple of many threads on subject, suggest run a search on the topic and narrow to the 61-66 forum.
https://www.ford-trucks.com/forums/7...cs-posted.html
Ford Truck Enthusiasts Forums - 66 twin i's Album: 66 F 100
Here's a link to easy2rider's gallery with add. info:
1965 Ford F100 4x2 - Restoration Process
I have some what bad rust on my floor pans too
I am restoring a 65 f250 and i am working on the floor pans it has a weird kind of tecture on the medal it is bubbly it is kind of just rough but i don't know how bad the rust truly is i cant tell there is no wholes in it and it seem pretty sturdy just a lot of surface rust this is my first restoration. I am thinking of using a floppy sandpaper grinding disk on top and bottom then using por15 on both sides. Do you guys have any ideas of what i should do i don't want to replace them if i don't have to. thanks
ccarrier
50
07-22-2019 04:25 PM
sbfishman
23
01-12-2010 11:47 PM
