2000 Buick Century Transmission Shudder
I have a 2000 Buick Century that I was given a couple months ago. Only has 46k miles on it and was owned by my parents for about 8.5 years.
Right after I got it I changed the tranny fluid (had never been done) and the first time I drove it I noticed that at certain throttle settings from a dead stop, it will shudder noticeably. It only does it from a stop and only at that particular application of the throttle (like 1/4 throttle). Gentle starts are normal. I have no idea if it did this before the fluid change but I had never noticed it.
Now, I have no idea why I tried this yesterday but if I start moving with the selector in "1", it will not do it. With the car in "2" or "1" the "TRAC OFF" light is on which I am assuming means traction control is disabled.
So, any ideas on this? I appreciate the help.
The tranny also sometimes shifts hard once the car is warm and has been driven for a while but it otherwise shifts great.
Also, there are no codes showing up on my reader. Would tranny codes need a special reader or should they show up on the OBD-II/CAN reader I have?
(LOGIC CHOPPING MODE)
It does it when "3" or above is engaged
No idea if a particular fluid is REQUIRED, and may not now have it
"SHUDDER" is typical of a clutch surface with a worn out material that now is metal-to-metal, and grinding up.
Continuous operation under recommended OD speeds IN OVERDRIVE can lead to premature wear of the transmissions clutches (particularly in the higher ranges)
*This gearbox is displaying signs of a unit that has been ignored, and wore out from uneducated use. An OD tranny that is left in OD constantly can turn into a machine that does exactly what you have described. The clutch packs can be replaced, and that ought to cure it.
Thanks for your response, I did figure it out I own a small general auto repair business and always utilize all data and internet blogs for further info it is sometimes very helpful, I took transmission pressure readings which indicate low fluid pressure in drive, that transmission utilizes a band and servo in first gear, the reason it doesn't happen when you put it in 1 or 2 it activates a second band and the fluid pressure doubles causing the servos to apply more pressure on the bands hopefully this may help others, there is no easy fix pressure can be lost not only through the pressure control solenoid but also the valve body and various seals ultimately you need a proper transmission rebuild from a qualified rebuilder, Thanks again
2006FOMOCO
10-15-2023 06:12 PM
BearMan54
1983 - 2012 Ranger & B-Series
33
02-13-2018 03:46 PM
NunchuckNorris
09-07-2015 07:03 PM
AllThingsFord
28
02-21-2014 05:09 PM
DieselBurner153
03-26-2013 05:29 AM
