Waste Motor Oil
I was just wondering about it.
Also read a article about a guy running used trans fluid (filtered a lot) in his 7.3 Excursion. Said he was running up to 90% ATF and 10% diesel with no problems.
I saw a system for filtering WMO and waste transmission fluid for use as a fuel. It's supposed to filter it down to 1 micron, then you can add it to your tank and mix with regular diesel in whatever mix % you want.
I don't see any issues running used ATF as fuel mixed with diesel as long as it's filtered a lot. I probably wouldn't do more than a 50/50 mix of anything with diesel. Not sure if running WMO would work as well.
on
Don't do it. I have seen pictures of peoples injector tips after running WMO and they were caked with deposits big time! Also as someone who uses WMO to heat our shop the ash left over (granted the oil is NOT filtered) is bad stuff! The furnace has to be cleaned out every year and has very fine ash that I am sure isn't real good on your injectors or piston rings.
Don't do large % of used ATF or WMO.
Yes, you can filter to 1 micron, but the filters won't last long and consider the cost fo the filters and your time and the damage that could be done to your injectors.
Also, you need to change your truck fuel filter every 3k - 5k miles, or at least I would.
If you insist on running WMO, I would do maybe 1 or 2 gallons per tank at most. And is that really worth saving $6 per tank with the risk you're taking?
You cannot run WMO at 80% or 90% successfully. I've had customers who have tried and failed and have expensive repair bills to show for it. Motor Oil is not the same as veggie oil. You can run the motor on 100% WVO, but no where near that on WMO.
I have about 30 gallons of WMO filtered to 2 microns, but never had the guts to burn it.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
The HEUI injectors, like in the Power Stroke, rely on lubrication from the fuel.
There is no lube left in waste motor oil.
Truck might run fine for an IDI, but it's an expensive repair to save a few $$$ in fuel.
__________________
