Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
  #1 (permalink)
Old 05-21-2010, 09:32 AM
brucear777 brucear777 is offline
Garage is empty, add now
brucear777 is starting off with a positive reputation.
how to change a Timken / Wheel Bearing/Hub Assembly-Front 2002 ford f 150 4x4
how to change a Timken / Wheel Bearing/Hub Assembly-Front 2002 ford f 150 4x4 Does anyone have Pictures and info on how to do this
Brucear777
  #2 (permalink)
Old 05-21-2010, 08:35 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a good reputation on FTE.steve(ill) has a good reputation on FTE.
here are some photos that may help... basically this is what you do.
--take off wheel and tire
--take off brake caliper and pads
--remove brake disc
--loosen axle center nut (maybe 32 mm?), take nut off.
---see if you can bump the alxe shaft inward an inch thru the splined hub
---on the backside of the hub there are 3 bolts with 15 mm heads holding the hub to the knuckle.
--the 3 bolts are TIGHT. you may need a GOOD 6 point wrench and a 5 pound hammer. i have a special combination wrench from Craftsman that i can pound on without breaking.
--after the 4 bolts are out, pull the hub off the knuckle, maybe need a hammer and pointed chisel.
--if the hub will not move off the splined axle shaft, you will need a puller.
--you dont need to remove the ball joints.
--support the CV joint after removal - dont pull it apart or pull out too far.
--wire brush the splines and antisieze prior to reassembly.
http://www.ford-trucks.com/forums/36...f-150-4x4.html
__________________
2001 SuperCrew 4 x 4 5.4 XLT - 220,000 miles
2002 Explorer 4 x 4 4.0 XLT - 152,000 miles
Tags
1999, 2001, 2002, 2004, 4x4, assembly, assemblyfront, bearing, bearinghub, bearings, change, expedition, f150, front, hub, replace, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
