Front and Rear Cab Mounts Removal??
How do I remove the front and rear cab mounts? I already got everything off the frame and ordered my new kit from CC but don't know how to remove the old ones. Do I need to sawzall them off? Do I cut them off with a cutting wheel? Do they somehow screw off?
Thanks a lot.
Thanks a lot.
Thanks a lot.
Thanks a lot.
Yes, they unbolt from inside the cab... under the gas tank and the front of the floor.
They are just rusted in. You should be able to get under them and knock them out from the bottom. When I did my truck they came out real easy. The core support mounts are the ones that gave me a fit tring to get out. Also it is a good idea to replace the core support mounts when you do the cab mounts. Your cab and fenders will line up a lot better if you do.
Luke76
05-11-2018 08:04 PM
Kuhns71
32
09-14-2012 08:26 PM
