Adding delay wipers?
on
I can answer your question though,.
1980-1991 F-series and bronco switches and modules are interchangeable.
Find yourself a 1980-1991 F-series or Bronco with intermitant wipers, remove the switch and the govenor box hooked to the switch and to the trucks main harness, then transplant it and hook it to your truck. Real simple upgrade and it is plug and play.
It would be better for you to find a module for a 1987-1991 truck as they were redesigned to fit into the dash better, but any module 1980-1991 will work.
Hope this helped you out.
on
You are talking about the steering column stalk wiper switch. (duh moment) That was introduced in 1992. Funny thing the English language.
As for interchangeability: Wiper modules and switches fit the following.
1980-1983 F-100
1980-1991 F-100/F-350 and U-150 (Bronco)
1980-1999 F-600/F-900
on
You can replace the 1973-1979 govenor modules and switches with the 1980-1991 style if you move the washer pump wire in the connector.
You can also put in these modules in 1972 and older pickups as well by switching the washer pump wire.
I have had issues with junkyard units not being fully functional, so you might pick up a couple switches, governors, etc...
The switch and governor in my truck now has high and low and the intermittent doesn't work right (can't adjust delay time much) and then I have another governor and switch that have low, no high, and properly-working intermittent. So you might end up mixing and matching.
Just a heads up
Just a heads up
