81 F100 Trans ID
Old 05-20-2010, 06:28 PM
masseysbronco's Avatar
masseysbronco
masseysbronco is offline
81 F100 Trans ID
Can someone tell me what trans I have? It is a 4 speed manual and the **** indicates it is an overdrive. It looks like the SMOD, but the case is aluminum. It has the fill port on passangerside, and speedo cable on driverside.
Casting#s
1B2880
RF-D9BR-7008-AB
C-2604302
Tailhousing#s
RF-E0TR-7F306-AB
C-2604302
FA1
Tag #s
RUG DB BA14
E0TRAB 1609
Old 05-20-2010, 10:25 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty
6fifty_f1fifty is offline
looks lik you have the wonderful rug srod tranny, is reverse up and to the left?
Old 05-21-2010, 07:19 AM
masseysbronco
Yes, but it doesn't seem to have the unique shift rail that the SROD is supposed to have. A mechanic told me that there was a 4 speed non-overdrive trans offered, and that it could be it. I'l post pics here shortly.
Old 05-21-2010, 08:06 AM
masseysbronco
OK, here is some pics to assist with identification:
Old 05-21-2010, 08:23 AM
6fifty_f1fifty
yep that is a srod, someone painted it black, but the ****ing rod is in the extension on the driver side of the tranny, se my photos of an srod:
and
Old 05-21-2010, 08:24 AM
6fifty_f1fifty
I must have typed something wrong, because it turned "shifting" to ****ing
Old 05-21-2010, 10:17 AM
masseysbronco
LOL,
Crap, I was hoping it wasn't the SROD. I saw a pic somewhere that claimed to be one, and the shift rail looked like it was on the top and about a foot long.
How hard is it to rebuild this tranny?
Should I remove it with or without the bell housing?
Any other comments or suggestions?
Old 05-21-2010, 10:47 AM
6fifty_f1fifty
I haven't rebuilt one yet, some say it isn't hard. I chose to swap mine out with a t-18. You can pull it out without the bellhousing, I found it easier that way.
Old 05-21-2010, 11:24 AM
masseysbronco
Did you drop the crossmember to get it out, or unbolt the trans and turn it out of there? I like that it has overdrive, beause its gonna have to take on DD duties, but I wish it wasn't so weak. I'll probably take it off by itself, and then remove the bellhousing after, because I believe there is a freeze plug behind it that is leaking. I'd like to check out the flexplate and clutch while I have the trans out, what should I be looking for?
Old 05-21-2010, 11:55 AM
6fifty_f1fifty
You can get it out without taking out the cross member but it isn't easy, with a tranny Jack it is almost impossible, but if you can handle he weight on your chest you can take it out manually without removing the crossmember
Old 05-21-2010, 12:35 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
Flex plate and Clutch ... I hope your flywheel doesn't flex! You got big troubles if it does!
-Enjoy
fh : )_~
Old 05-21-2010, 03:34 PM
masseysbronco
lol,
Yeah transmissions aren't really my thing. So what use a flexplate, an auto? Does the clutch just contact the flywheel are what? I personaly don't care for manuals, but this is not my truck.
Old 11-10-2013, 06:10 PM
bbyrnes1's Avatar
bbyrnes1
bbyrnes1 is offline
I have the same transmission with the shifter mounted to the side of the tailshaft. Is this a specific type of T170 or what? It's proving hard to even find pictures of one with the side shifter.
Old 11-11-2013, 05:44 PM
bbyrnes1's Avatar
bbyrnes1
bbyrnes1 is offline
Desperately need transmission part
Alright guys here's why I ask: I just acquired the original Tremec SROD 4 speed tranny and the potmetal shift turret housing on the side of the tailshaft is rotten from sitting in the dirt, so I can't mount my shifter. Can ANYBODY please help me find this part?
circlecityrabbit
02-16-2015 10:28 AM
907outdoorsman
1997 - 2003 F150
01-27-2013 09:38 PM
danlee
08-17-2012 06:20 AM
Big.Dave
10-06-2010 09:23 AM
fixyourdns
05-24-2010 02:55 PM
Quick Reply: 81 F100 Trans ID
