air emission tubes ? - Ford Truck Enthusiasts Forums
Old 05-20-2010, 06:44 PM
drunkenrich drunkenrich is offline
drunkenrich is starting off with a positive reputation.
Hey guys
I have a 93 f250 with a 351 v8 and it's 8600 gvw. Anyways, I pulled the engine out months ago and am reassembling and I'm almost done, 1 thing I cant figure out is where the two air tubes from the Cat Convertor hook up to? I have them on the cat and then going up to another piece and then nothing. Can someone take a picture of where theirs goes, i hope I didn't misplace a peice,. thanks
Old 05-20-2010, 08:32 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
Lol, heres where all mine went:
Sorry, i got rid of mine when i did my engine swap. went to long tube headers and never looked back!
Old 05-20-2010, 10:50 PM
anyone? do you have to worry about passing emisions if you take all that out?
Old 05-21-2010, 01:31 AM
|WYG|SS's Avatar
|WYG|SS |WYG|SS is offline
|WYG|SS is starting off with a positive reputation.
i think you would have to worry about passing emissions cause that helps keep them down. their should be like a black tube on back of engine with maybe a little silver piece on the end.
Old 05-21-2010, 07:12 AM
i just need a picture, anyone?
Old 05-21-2010, 08:30 AM
robprime robprime is offline
robprime is starting off with a positive reputation.
I threw mine away too, but if I remember right there should be a metal tube that runs from head to head across the back of the motor and it has a large hex fitting sort of in the middle. That fitting hooks up to a mass of tubing and vacuum valves that mount over where your coil is. The two tubes from the cat connect to the mass of tubing. I still have the pieces in my garage and I guess I could lay them out on the floor and take a pic if you still need one.
Old 05-21-2010, 09:20 AM
that would be great robprime! thanks. Rob,does your truck run any different without all that emissions stuff on? if i didn't connect the two tubes from the cat would it affect my performance?
Old 05-21-2010, 11:03 AM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
If you are not connecting the tubes at the cats then there's no point reinstalling all the other hardware.. pumping air to the cats is the only reason the system exists. The motor will run fine without it too as long as any holes in the exhaust system upstream of the O2 sensor are plugged and there are no vacuum leaks. For the record the AIR system on HD trucks is configured a little differently than the 1/2 tons, instead of pumping into the back of the heads it usually goes into the exhaust manifolds by the collector, and the diverter valves are mounted on top of the engine instead of behind and beside it. There was a posting here a little while ago with pictures of the smog setup on an F250 but damned if I can find it now, maybe do a search yourself if you really want to see it.
Old 05-21-2010, 11:05 AM
but will the truck run any different? will it hurt the engine? etc?
Old 05-21-2010, 11:15 AM
Conanski's Avatar
No.. the air injection system has no effect on engine operation at all, it only affects tailpipe emissions and even then it only improves emissions on cold starts.
Old 05-21-2010, 01:14 PM
so if i run the truck with the cat on and all the other emission stuff on without the pipes hooked up (just plug holes in cat) will it mess anything up, like the smog pump or anything?
Old 05-21-2010, 01:40 PM
Conanski's Avatar
No.. that will be fine too.
Old 05-21-2010, 04:01 PM
Paul,
Are the wiring connectors for those valves still in the same place? I was going to reccommend that he order three of those large resistors from RJM to put across the connectors to keep the check engine light off. I've done it to mine and they work fine. I just shortened the leads and soldered some mini blades to them. Plugged them in and taped them up. No codes after I did that.
Rich,
My truck was running fine until the PCM started messing up. I've also removed the EGR and the smog pump. Got rid of quite a bit of engine bay clutter.
Rob
Old 05-21-2010, 06:03 PM
Conanski's Avatar
The air control solenoids are in the same place.. next to the coil. I know some guys are hell bent on removing everything but if you leave them there and keep them electrically connected that will keep the CE light off too.
Old 05-21-2010, 06:37 PM
LCAM-01XA LCAM-01XA is offline
LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.LCAM-01XA has a very good reputation on FTE.
The idea behind the whole AIR system is to pump air (thus oxygen) in the cats and the back of the heads (or manifolds on the HD trucks) to help the cats start their chemical reactions faster on a cold engine. Once the engine warms up the air supply to the heads/manifolds/cats is shut off and everything pumped by the smog pumped is just being vented out into the atmosphere again. The AIR system can be safely removed from the truck, without affecting emissions testing results, provided testing is done with the engine fully warmed up (like it should be done anyways). There is a catch tho - you can remove the plumbing and the diverter valves, and you obviously plug any loose ports in the heads and manifolds and cats, but you have to leave the control solenoids plugged in their harnesses - the PCM really only cares about "seeing" them through the electrical signals it receives from them (it grounds them to trigger them), so as long as the harness is still plugged in then you can remove everything else (including the rats nest of vacuum lines) and there will be no error codes in the PCM.
Oh yes, you can only do this is counties where there are no visual emissions checks, as not having the AIR system will in many cases give you an automatic fail even tho your truck runs perfectly good and passes the actual sniffer test with flying colors...
1992 F250 V8 5.8 Smog/Air pump Markus Mueller 1987 - 1996 F150 & Larger F-Series Trucks 2 10-01-2016 06:08 PM
Tubes going into cat turbosporsche 1987 - 1996 F150 & Larger F-Series Trucks 2 10-28-2015 10:29 AM
'92 F250: looking for part #s for air tubes to cat. conv. edbee 1987 - 1996 F150 & Larger F-Series Trucks 4 07-28-2014 12:03 PM
Air injection to Cat 91 Bronco 351W gov2mod 1978 - 1996 Big Bronco 1 09-16-2010 05:53 PM
Hose for air injection into cat?? boggerted 1987 - 1996 F150 & Larger F-Series Trucks 9 07-15-2009 11:49 PM
Tags
1996, 302, 351, 49, 86, air, back, control, emission, emissions, f150, ford, heads, pipes, pump, smog, tube, tubes
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
