f600 hubs
awhtx - e-mail me at yamaha_kodiak_450@yahoo.com with this info
1960fordf350 - can also email me I thought you had two 22.5 wheels
Why do you want Dayton wheels when you have good Budd wheels? What year truck do you have? The wheel that is commonly reffered to as the widow maker is the split rim. The tube type wheel with the snap ring on one side is a different wheel and is safe. Just make sure when you are airing it up that the snap ring is securely in place and turn it over with the snap ring on the botton. Back to your question, if you just want Dayton wheels you will probably have to change the front axle unless your truck has the heavier front axle that a 750 has.
I have a 1963 f600 with 6 split rims (widow makers) I have looked at a few truck (in Pics) that have the dayton style wheels , I can not find anyone local that will mess with a spit rim, closest place if they even still do is 1 hour away, I have done the work before and not a fun job, but if I could find a way to go tubeless or have someone else do it (guess I'm getting lazy in my old age) I have looked into getting 19.5 and 22.5 wheels but the cost is way to much , if I could only come across some close ??????
If I am not badly mistaken they quit making split rims in the 50's. Your 63 should have the snap ring type.
This is the snap ring type and has not been outlawed. If you have this and they refuse to repair or mount a tire they need to be educated as to what is a split rim and what is not.
This is a split rim, look close at the wheel near the center of the rim. See where the rim splits. The rim is a two piece set up. This is the one that has been outlawed. You cant see when it is locked whereas you can see when the snap ring type is locked in place.
I am sorry if you took offense to my explanation of the difference between split and snap ring wheels. This question has come up in the forums a number of times before and it never ceases to amaze me as to how many people do not know the difference.
The 55 with the six luggers on it.
my screen name, is for my 1948 f1's, I have several of them .the truck I 'm trying to find wheels for is a 1963 f-600 , I 'm sorry if I came across as being rude but I do know the difference, between the different styles of wheels I am trying to find a cheap way to gett away from the widow makers is my goal, I was just wondering about the dayton hubs I have seen several with 900 20's laying around and was just thinking ??????
Rather than outlaw them or force a recall, OSHA accepted the manufaturers' lobbiests' position that the many RH-5° failures were due to faulty training practices. In addition to increased training, tire shops were required to display safety posters. This weak federal action saved the manufacturers millions of dollars but did little to improve safety. As a result, the courts have awarded many wrongful death and injury awards, and the insurance companies have adjusted rates accordingly. That is why most reputable shops won't touch the things anymore. Here are good pictures of a widow maker showing the joint at the middle of the rim.
Otherwise, I agree completely that lock ring style wheels are generally available and safe to use if undamaged and handled correctly. In fact, lock ring designs are still sold new today for demountable applications. Availability depends upon your bolt pattern. If I read right that you have an F-600, you've probably got 6 lug x 8.75" bolt circle. Some like this that I've seen are hub piloted but most are stud piloted. If you are unfortunate and have hub piloted in this bolt pattern, no new wheels are being made. Stud piloted are still sold new by Accuride. Stu
Edit - I was typing on top of you. The trucks I've seen that were hub piloted were of your truck's era. That's not encouraging. If you do have stud piloted there should be plenty of used tube type lock ring 20s or tubeless 22.5 in yards that have the 6 lug x 8.75" pattern. Stu
I've had two discussions with guys in your spot over on the 48-60 page. Both have taken the same approach. They've swapped the lugs to eliminate the ledge that extends out into the inner rear dual on the stock lugs. I don't recall the one thread, but I'll see if I can do a search and find you the other one. I think its title is "the real widowmaker". I'll come back and edit if I can find it. Stu
Here you go.
https://www.ford-trucks.com/forums/8...er-wheels.html
Also, here are cross section diagrams of both the stud piloted and hub piloted systems. The first is the stud piloted, then the hub piloted. If you compare you'll see that the inner dual of a stud piloted mount will hang up on the hub piloted inner lug/stud ledge. To allow the stud piloted inner cap nut to seat you've got to get rid of that obstruction. Stu
Here you go.
The term split rim seems to get applied by somebody or other to just about every type of multi-piece wheel there is. I think for many people it means anything other then a disc type drop-center tubeless rim.
My '63 N600 has the same problem as mo1948f1 - hub piloted widowmakers.
