OBS DIY Intake
OBS DIY Intake
I bought the parts yesterday to get this job done, but I took a slightly different approach than most of the DIY setups you see. I already had some 4" exhaust tubing with a 45° bend in it, so I bought the same filter, filter holder, and rubber boot that the Tymar intake uses (yes, the exact same parts). I also bought some T-bolt clamps, I decided not to use constant torque clamps because (1) they were twice as expensive (and my wife about **** herself when I told her what I had spent already) and (2) I'm not 100% convinced that the constant torque clamps are necessary.
$118 worth of parts from Air Flo Systems.
The lovely stock OBS intake (with a K&N hiding inside the airbox )
What I did with the IAT sensor
This hose coming from the vac pump was touching the rubber boot that couples the 4" exhaust tubing to the CCV housing.
Shortened the hose a bit
Much better
Finished product
Its not 100% perfect at the moment but it was getting late last night and I wanted to get it back together. I cut the exhaust tubing just a little too long and the hood hinge lightly rubs the filter when I close the hood, but other than that I'm pretty happy with it.
Much better
Finished product
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Air Flo Systems
Could I have bought the Tymar kit and spent less? Probably, but I already had the exhaust tubing so I just bought what I needed and put it all together.
All the parts came from Air Flo Systems, same place Tymar buys his parts I'm pretty certain. And James is right, the clamp just slides over the filter to give it a little clearance on the bottom. Necessary? No I don't think so. But Dale @ Tymar is adamant that it is needed for proper radial clearance/performance. I figured why not buy it and use it.
Air Flo Systems
Air Flo Systems
Yes this was what I wanted to know. I fixed, my custom clamp, in one of the supports for the old crap intake.
He only mounts it to the battery tray in the SD's. Something to do with the way the wheel well is shaped, the filter clamp doesn't have to be secured in the OBS. But when he was testing on the SD's he found that it needed to be secured.
