Whats with the no body lifts?!!??
I know that big JoeF350 made a 3" for his rig, but has anyone else put a body lift on their's?
No company makes a bodylift for my 1994 F350 7.3 IDI. Id like to raise 1" or 2" for a 2.25 or 3" downpipe AND Id also like to fit some 37" MTZ's wrapped around some 20's.
anyone? Thank you in advance
ive got a 1.5" on mine. nobody makes one for the diesel, but it is the same exact one as the gas. same body mount points and everything. you can just get one for the gas model. word to the wise though!!! your fuel neck hoses are going to be really tight. you are going to need to buy or make a bumper lift relocation brackets and thats gonna open your radiator up to getting hit by rocks so your gonna want a spoiler under the bumper.
most any 20 you can find will be too wide, and force you to eithier lift a lot or trim the wheel wells, I think you could get away with just trimming the fenders out and that very small body lift, but you may get into a suspension rub and end up havig to limit your steering stops.
oreo's got a real nice looking setup, I wouldn't mind seeing some close ups of his trim job
AirBagIt.com - Air Suspension Kits, Mini-Truck Parts, Sport Compact Parts! Airride, Airsprings, Towing Kits, Lambo Vertical Doors, Airbags.
way way cheaper then the plastic ones. id have gotten these if i found them sooner.
I have a 2'' on mine... I think they all say "not for diesel" because the drivers cylinder head can/will hit the fire wall after the lift... or at least that's what mine and other peoples do.
The reason I was given when I phoned up a supplier was that they were worried about the mods to the cooling system that have to be made and the possibility of over heating and a law suit...
